E36 (1991 - 1999)
Old 11-25-2012, 10:39 AM
glenda299 glenda299 is offline
Mein Auto: bmw e36 318
318 3e6 1997 blower motor not working
hi i got in the car today went to turn on the blower and nothing happend no air or noise
its always been loud on full speed i dont no if this is how it should be also it takes ages to get warm inside car the engine runs fine and has had a recon head fitted but i need advice as should i change the blower motor or should i do the resistor pack as everything else seems to work and checked fuses
Old 11-25-2012, 11:00 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Resistor pack first. Always check the easy things first. If you end up changing the blower motor out, you'll see why you check the fuses (you did ) and the resistor pack before tackling a blower motor change-out. If it has been running wide open for a while with no other speed working, that was the resistor pack failing.
BTW, welcome to the fest!
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
blower fan
