E46 (1999 - 2006)
Old 11-25-2012, 12:26 PM
JoshBosh JoshBosh is offline
Mein Auto: 1994 BM
Exterior Door Handle Problem - Fixed one problem, created another
My E46 fell victim to the seemingly very common issue of a broken exterior door handle. After coming across a post, I set out to do a DIY fix. I managed to squeeze my hands into the very tight space and get the zip tie in place to hold the cable and keep it taught. This got the actuator action on the cable working correctly but seems to have created another issue.
The cable seems to be too long and it fails to pull on the opening mechanism at the end of the cable. The pictures show that the cable is so far above the mechanism that it doesn't engage it and open the door. I tried a zip tie linking the end of the cable to the mechanism but it didn't activate properly.
I uploaded some pictures. The first shows the end of the cable without the exterior handle pulled. The second one, the handle is pulled. You can see that the cable pulls about an inch or so but it's so long that it doesn't activate the mechanism.
The last picture is my zip tie fix near the top of the cable.
Any suggestions? Has anyone else had this problem?
ID:	350769   Click image for larger version
ID:	350770   Click image for larger version
