E46 (1999 - 2006)
Old 11-25-2012, 06:59 PM
brainblonde brainblonde is offline
Mein Auto: 328i
New Key
If a new key is purchased for the car. What process has to be done in order for the key to work?
Old 11-25-2012, 07:43 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
If you want a *REAL*, reliable key that will activate all the proper functions, you have to get it through the dealer. Price varies, anywhere from $175 to $225.
The road goes ever onward....
(R.I.P. Jever)
Old 11-25-2012, 10:17 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
You need proof of ID and ownership.
And dealer has to program it.
Old 11-27-2012, 10:02 AM
Bimmer3Series Bimmer3Series is offline
Bimmer Lover Since '96
Mein Auto: '99 328ic,'01 325xi,'05X3
Master KEY?
We picked up our '01 325xi in Sept. & only had 1 master key (for my wife) which worked fine. I ordered another (for me) from a dealership, got it last week, programmed it & it worked fine. Well, my wife hasn't driven the car since last week due to illness but I have with my key & it worked fine. Today, she drove the car but said the key would not lock the car. I tried hers & sure enough, no lockee... my key locks & unlocks fine. I tried putting the key in the door lock but I couldn't get that to work either unless I just wasn't turning it far enough. Her Key that we got first had just had a new battery put in before we picked up the car... So, what is the deal?? Is her Battery dead or does it need re-programmed? Shouldn't the key still be able to lock & unlock using the driver's door lock?
Old 11-27-2012, 10:21 AM
joegr joegr is offline
Mein Auto: 2002 325i
Originally Posted by Bimmer3Series View Post
... Shouldn't the key still be able to lock & unlock using the driver's door lock?
If I remember correctly, when you programmed the new key to remotely lock and unlock the doors, you erased the old key (for locking/unlocking only). You have to program all keys (two in your case) for remote locking at the same time.
As for it not working in the door lock, either you didn't turn it far enough or your mechanical lock linkage is broken. If it is broke, I'd fix it before you get locked out.
Old 11-27-2012, 11:26 AM
Thanks for the reply. So, how do I program both keys at the same time? I had to put the new key in the ignition, turn to position 2 (without starting car), turn back off, remove key, hold down the unlock button & push the lock button 3 times. If I do this again with the "old" first key, will it erase the new key then?
Thanks for your help. I'll try the key in the door lock again when I get home, the car's in the garage, driving the old trusty '92 318ic.
Old 11-27-2012, 11:41 AM
Do one of the keys just like you did before. Then right after you finish the first key, grab the second key. Hold down the unlock button & push the lock button 3 times on the second key. Don't turn the ignition switch for the second key, and don't open the car door until you are done.
Old 11-27-2012, 11:51 AM
Cool, thank you!!
