Rpm's - Bimmerfest - BMW Forums
Old 11-26-2012, 11:33 AM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645 / 14 435I
Rpm's
I have a 05 645, I don't have a lot if issues but I have one that when I start it up sometimes the rpm goes up and down and almost turns off.
Any ideas?
Old 11-26-2012, 04:43 PM
HerbP HerbP is online now
It could be from a thermostat going bad, or a purge valve problem. This usually happens on cold morning starts, & is not really a problem to worry about. When you start getting a code, you will find the culprit.
Good Luck!
Old 11-26-2012, 04:51 PM
D Woolley
I dosent happen in the morning but when I drive around then go inside somewhere and then when I start it up.
