E36 (1991 - 1999)
Old 11-26-2012, 05:20 AM
sweeper3 sweeper3 is offline
Mein Auto: E36 328i
Help "Rear brake sensor
I just replaced my rear rotors and pads and at the same time decided to replace the wear sensor. Now I have a dash light on, i tried replacing with the worn pad, since it never hit the wear sensor and still have the light.
I put an ohm meter across the two leads and it shows a dead short between the leads. I did this on the old one and new one, they show the same. But it has the light.
Do i need to reset this from a stealership or is there another solution..
1998 328i
Thanks very much
Rob
Old 11-26-2012, 08:56 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Check the connection of the sensor to the harness in the wheel well. The sensors operate as a continuous path (what you called a dead short). When it wears through it opens the circuit and you get a brake wear warning light. If you're getting a wear light with a new sensor, it's not making connection with the harness.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 11-26-2012, 10:36 AM
Mein Auto: E36 328i
This what I was thinking. Both the new sensor and old one show the same thing. I've opened the connection box thinking a pin was bent or something, nope. I will look again to see if something isn't connected.
Thanks for replying. I wasn't sure if i needed to go to a dealer to get the code reset. I guess not!!
Thanks again I'll post up what I find
Rob
