Old 11-26-2012, 07:44 AM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
intermitent (Auto) wipers do not work
Ok, this used car I got has a aftermarket windshield. Sensor is plugged in. Really annoying. HI & LO work find. But the intermetint works off the sensor so I basically have no intermetint wipers. Is that sensor replacable or do I have to have the windshield replaced?
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 11-26-2012, 09:25 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Check, and make sure the connections behind the windshield are attached correct. Also, check and see if the sensor glued to the windshield has no visible bubbles. Check this out for pics.
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 11-27-2012, 07:15 PM
sktn77a sktn77a is offline
Mein Auto: 2001 BMW 530i
Most likely they installed a windshield without the sensor lense pre-installed. As explained above, if you try to stick the old lense back on, it leaves bubbles and imperfections in the adhesive layer. The guy in the E46 link was lucky - it's nect to impossible to get a clean installation after-the-fact.
Keith
2010 Prius
2008 Lexus IS250
2005 Prius
2001 BMW 530i
1999 Lexus RX300
Old 11-27-2012, 07:50 PM
nice. I will look at it this week.
Old 11-28-2012, 04:13 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Just curious (I am no rain sensor expert)....Is there a way to bypass the rain sensor, tricking it into thinking it is slight rain?
Old 11-28-2012, 05:02 AM
^ would be nice. Just put a resistor inline and you could use the intermitent wiper like a normal car. Please someone tell me this is possible.
Old 11-28-2012, 07:49 AM
doru's Avatar
To activate the rain sensor, you push the stalk up one notch, then you flick the dial all the way up, then back down to the min position. This will activate the rain sensor.
If you want intermittent feature, you place the stalk at the same position, but you just place the dial in the desired wipe speed position, making it work like any other car.
The advantage of the rain sensing wipers is that it's vehicle speed dependend, making the wipers move faster as the speed of the car increases, and almost stalling when sitting at a red light for example (if it's light drizzle, not heavy rain). The heavier the rain, the faster the wipers move, and I think I witnessed them moving what seemed faster (on rain sensing) than on the fastest setting (highest push up of the stalk).
Old 11-28-2012, 07:54 AM
You may want to read this E36 thread then unplug it.
Report back the result:
http://www.bimmerfest.com/forums/sho...d.php?t=601496
http://forum.e46fanatics.com/showthread.php?t=750651
Old 12-01-2012, 06:38 PM
^ Did not know about activating the sensor like that. Interesting. so my intermitent wipers don't work either. Might try just unplugging the sensor and see if the rotary dial works like old school intermitent.
Old 12-01-2012, 06:50 PM
Dking078's Avatar
Dking078 Dking078 is online now
Nor genius Nor ignorant
Mein Auto: 2003 BMW 540i
Heres how it works (from the manual) For somereason, i thought it was to just leave it in pos. 1. Goes to show we learn new things everyday
Rain sensor:
The rain sensor is positioned on the
windshield, directly ahead of the interior
rearview mirror.
To activate the rain sensor:
Move the lever to position 1 with the
ignition key in position 1 or higher. The
wipers travel once across the windshield,
regardless of the weather
conditions.
You can leave the lever permanently in
position 1. Whenever the ignition key is
in position 1 or higher, all you then need
to do to activate the rain sensor is
briefly turn the rotary dial 7.
To adjust the sensitivity of the rain
sensor:
Turn rotary dial 7.
Deactivating the rain sensor:
Move lever to position 0.
~The Fun Cars~
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [DSP] [AUX] [ICE V5] [BSWs] [DINAN Trans] [M Audio Subs] [E38 lighted int. door handles] [E46 Paddleshifters] [Two-tone Interior]
2008 BMW 550i [Jet Black / Black]
[Sport] [Paddles] [Comfort Access] [IPOD] [Shades] [Nav] [PDC]
A 5'er that was almost too good to be true.
Stuff For Sale:
OEM E39 Nokia Subwoofer [click]
Old 12-01-2012, 09:10 PM
champaign777's Avatar
Mein Auto: 2010 550i M Sport
this thread might help
http://www.bimmerfest.com/forums/sho...355&highlight=
E39 4 ever
M54 GARAGE SALE
2003 530i 107k miles for SALE
