Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 11-26-2012, 12:42 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
F30 max winter tire diameter
hi gary. yet another winter tire question.
i see you guys have 215/55/17 listed as a fittement for the F30. do you think there would be any issues going to 225/55/17. diameter goes from 26.7 to 26.8
have my tire choices narrowed down to the LM60 in 235/50/17 or the 3D run on flat in 225/55/17
thanks!
edit: odd, it looks like only the wintersport 3d in 215/55/17 is listed at 26.7. all the others are 26.3
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 11-28-2012, 07:47 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
The correct diameter of tires in 215/55R17 is 26.3 (the dunlop listing is a typo). We have not tried the taller and wider 225/55R17 so unfortunately I cannot say for sure if that size will fit without rubbing. It looks likely, but we have not tried it yet.
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Old 02-01-2013, 03:46 PM
hey gary,
an update, got the LM32s in 225/55/17 on sport edition A7s (the recent order that went to MA)
the taller tires fit, no rubbing, good clearance around the spring perch in front, fender/shock in the rear.
small bonus, speedometer is now spot on
Old 02-06-2013, 07:42 PM
lrchmbl lrchmbl is offline
Mein Auto: 2013 328i
Mr. NYC-
I note that your present BMW is a 2013 335i. Is that an F30 or an E9x? I'm looking at getting those same tires for my F30 328i. Thanks in advance!
328i, ZMM, Superman, 2PE w/ZPT, ZCW, ZDH, ZLP, ZPP, ZTP, Sport 8AT, HK, Rear-view, PDC
Old 02-07-2013, 03:19 PM
Originally Posted by lrchmbl View Post
mr. Nyc-
i note that your present bmw is a 2013 335i. Is that an f30 or an e9x? I'm looking at getting those same tires for my f30 328i. Thanks in advance!
f30
