Old 11-26-2012, 04:52 PM
bimmerized bimmerized is offline
Mein Auto: 97 E36M/4
help! car wont start, codes attached
My 01 330 M54 recently started running rough and threw codes.
Had the codes read and they were:
P0171B, Bank 1 Lean
P0174B, Bank 2 Lean
P0300B, Random Misfire
P0313, Misfire
P1083, B1 Lean B1 Sensor
P1085, B2 Lean B2 Sensor
P1342, Misfire at Start Cylinder 1
So based on the codes, I figured it was one of the ignition coils that's gone intermitent. So I go to check them physically and fine one whos frame is starting to melt. (Happened to be a Bremi/BMW at cyl 5. while the rest were BMW/Bosch.) I replace that suspicious one with a new Bosch unit and at the same time I noticed the plugs looked a little worn after 50K so I changed those too. the plugs looked a little rich to me, black soot, but not oily. Boots looked fine.
Put it all back together and it wouldn't start at all.
Put back the suspect coil just to see if I could get it to run again and it wont start either. Then I start swapping the new coil all cylinders one by one and trying to start, but no combination worked.
could I have more than one bad/weak coil and they got worse when I touched them? Should I buy more? the entire set? Do they all eventually go out after set amount of life, like lightbulbs and so maybe more than one are bad at the same time?
could I have a different problem, like a fuel problem? Car has been well maintained since owning it for the past two years. I have records of most everything replaced (except for that one Bremi coil...).
Please help! Any clues or suggestions are welcome. Coils are somewhat expensive so I don't want to replace them all if i don't need to and most say just to replace them as they go out. Thanks!
BTW, I also charged the battery for full current, to no avail.
Old 11-26-2012, 10:04 PM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
Is your engine cranking? Making a clicking noise? Can you hear the fuel pump prime?
