The X5 SAV Forum
Old 11-26-2012, 11:43 PM
garybeazley garybeazley is offline
Mein Auto: X5
Electric window in X5
when i close the drivers side window in the X5 it closes fast and bangs loudly, i can run it up to place slowly and its not so bad. Is it possible to adjust the speed it closes? or do i need to replace somthing?? Any advise appeciated
Old 11-27-2012, 02:35 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
I've never heard of anyone coding the window to roll slower. I will say it is frightening the first time you see/hear it.
But remember it is a solid German SUV (SAV). It's something you'll get used to. Remember it also has the anti-trap
feature which reverses the direction if you stick a hand out the window while its rolling up. (Don't let fingers get
trapped by any means). And all the windows should run about the same pace. If any one is significantly slower, it's
time for a new regulator.
Old 11-27-2012, 08:41 PM
Mein Auto: X5
window problem
The issue really is that when it stops it does so with a loud noise as the glass hits the frame, which made me wonder if there was a way to slow this last closing part down. Or do i need to re[place something. I am concerned the glass may break or maybe this is normal??
Old 11-28-2012, 07:38 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
is this behavior the same on all windows? if not the motor is suspect on that one. Mine is fine, move about the same on all my BMWs, no bang no jam, and pretty quite.
Old 11-28-2012, 08:54 PM
Mein Auto: X5
window problem
Yes, I have a feeling you could be right, i will go to the dealer and get it checked out, thanks for the advise most appreciated.
Gary
