Old 11-27-2012, 02:38 AM
Vex500 Vex500 is offline
Mein Auto: 2014 F15 X5 30D
Replacement battery
Hi there,
My 2008 3.0sd Is not holding battery charge, and as the car still has an original battery, I am thinking its time to replace it with a new one. My question is, does the car need to be recoded once the new battery is fitted? Any other tips or recommendations would be appreciated!
Thanks.
Old 11-28-2012, 10:53 AM
tlim66 tlim66 is offline
Mein Auto: BMW X5 35d
Where is the battery and how do you get access to it
Old 11-28-2012, 12:00 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Under the floor of the cargo area. Check your owner's manual for details.
P.S. Note that for battery charger usage, BMW recommends using the terminals under the hood, rather than a direct connection to the battery.
Old 11-28-2012, 12:07 PM
Originally Posted by Vex500 View Post
Hi there,
Thanks.
Theoretically-speaking, the computer needs to be told that a new battery has been installed to optimize the charging algorithm stored in the computer. This is clearly the "right" way to do it.
Practically speaking, opinions vary, with some people claiming not "recoding" will result in a battery dying in months from overcharging, while others claim that it will not have a major effect, and that the cost of any reduced life of the battery is less than the cost to have BMW dealer code it.
There is a general agreement that recoding is more important if the type or amp-hour rating of the replacement battery is different.
Finding an independent BMW specialist who has the equipment to recode it at a lower cost than an BMW dealer is probably the best approach, if you have one nearby.
Old 11-28-2012, 02:20 PM
ard ard is offline
Resident Curmudgeon
FYI... The term is 'registering' the battery if you are just replacing the battery.. 5 minutes work by someone with proper BMW computer/software. It is NOT reprogramming, or anything complex.
If you change the size/capacity then you need to recode it. (ie tell the car a different capacity battery has been installed) Add one minute to the job.
Old 11-28-2012, 02:37 PM
DPP528's Avatar
DPP528 DPP528 is offline
Mein Auto: 2000 528i Sport Prem 5Spd
Replace with the OEM battery, it's worth the money. My car is over 12 years old with only the second battery. The battery is going on about 8 years already. My alternator died and the 8 year old battery kept my car running for 120 miles before it stopped. Worth every penny.
2000 528i Sport Premium 5speed
Old 11-29-2012, 02:11 AM
Thanks, we have got the car booked in with an independent BMW specialist to get the battery replaced, they have not said anything about the recommended recoding but I will put this to them when I get it done. Thanks again guys!
Old 11-29-2012, 10:42 AM
ard ard is offline
Resident Curmudgeon
Do you mean OE? like 'a BMW battery'? Or the OEM that made the OE battery but now sells it "oem" with their own name on it?
Understand that the X5 is made here in the USA ...the days of a solid, german OE battery shipping with the car...and the wisdom of seeking this import again from Germany when it is time to replace it...may be gone...
Who IS the OEM for the X5 battery anyway?
Old 11-29-2012, 03:02 PM
DPP528's Avatar
Shouldn't make a difference, whichever's cheaper, the batteries usually retail for about ~$160 USD
Old 12-08-2012, 11:33 AM
GPSnV1's Avatar
GPSnV1 GPSnV1 is offline
Mein Auto: X5 5.0i
The only place I could find the right kind of battery for my 2009 4.8 X5 this morning was WalMart. So I should not go this route because there could be an issue with coding and their battery might be deficient? I started at Sams but they didn't have H8 in stock and couldn't find the battery!
I have an appointment with the dealer Tuesday AM, but am not willing to pay $350 for coding.
2008 X5 4.8i. 2012 X5 5.0i retired, 2004 X4 4.4i retired
BS RL/EL, Max 360, V1 (3.894) V1C LE/V1 Driver
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS
Old 12-08-2012, 01:02 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
Have you tried a place such as Batteries Plus? I have had luck finding an appropriate battery there.
Old 12-08-2012, 01:06 PM
GPSnV1's Avatar
Mein Auto: X5 5.0i
I'm sure they would have it but should I worry about the re-coding issue?
Old 12-08-2012, 01:12 PM
GPSnV1's Avatar
Mein Auto: X5 5.0i
I just called the local Batteries Plus and he said they only to '10 minute installs' so I'm not sure what they would say about the battery being under the cargo area.
Edited to say that there are not many places that will do this:
Old 12-08-2012, 01:14 PM
That battery is very easy to access. Be warned though, every light possible will be on for a little while after replacement...I just sent you some info as well (PM)
Old 12-08-2012, 01:21 PM
For what it is worth, I replaced my battery almost 3 years ago from Batteries Plus, and did not register. I have not had any issues. That being said, next time I will have my indy register. If I was you, I would seek out an indy in the next week or so to register. I would go ahead today and replace.
Old 12-08-2012, 01:47 PM
GPSnV1's Avatar
Mein Auto: X5 5.0i
Thanks for these suggestions. In the meantime, I am also trying to sort out the importance of registering and coding as explained here: http://www.xoutpost.com/909173-post16.html
Old 03-24-2013, 08:32 PM
Redskin Redskin is offline
Mein Auto: 528i
Is there are coding tool on the market that you can reprogram (re-code if a different Battery) and and register that is not ridiculously expensive?
Old 03-24-2013, 09:49 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
same battery type and capacity------> you only have to register.
different capacity or type------------> you have to do both registering and coding.
