Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 11-27-2012, 09:11 AM
740ix5 740ix5 is offline
Mein Auto: 740I M, x5 4.4
Stability control issue
I have my stability control light go on then the tire pressure light right after. Pushing the buttons don't work. 02 m3. Any ideas?
Old 12-11-2012, 03:11 PM
m3e46freak m3e46freak is offline
FREQ
Mein Auto: m3
Stability controls, such as DSC yes and then the tire pressure light after...
Make sure your bolts are tight on your tires by pulling on them hard. Also check your fuse box for that DSC/Tire pressure system. There should be a fuse key in the glove box and under the hood.
Old 12-12-2012, 01:54 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Speed sensor problem.
Stability control and tire pressure monitor both use the wheel speed sensors for input. The lights are telling you that something is wrong.
First step is to clean then. Then, if that does not work, you need to figure out which one is bad and change it.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-12-2012, 04:15 AM
FREQ
Mein Auto: m3
Another good idea, I did not know that I will make a note.
