E36 (1991 - 1999)
Old 11-27-2012, 09:47 AM
Bimmer1995318ti's Avatar
Bimmer1995318ti Bimmer1995318ti is offline
Mein Auto: 1995 bimmer 318ti
E36 fuel filter
Hey gents and ladies, I want to change my fuel filter soon, anyone know of a diagram or a pic of it somewhere? Also can I expect any performance gain out of changing it ? Thanks
Old 11-27-2012, 09:48 AM
Oh I forgot to mention it's a 1995 318ti
Old 11-27-2012, 10:34 AM
jitsjaf2009 jitsjaf2009 is online now
Mein Auto: 1995 BMW 325i Convertible
I know of 'heartaches' you may experience for having a clogged or failed fuel filter. resolution of these would be the performance benefit. Also unseen, a dirty fuel filer can cause more work for the fuel pump and possible failure of same. In one case with another vehicle my acceleration was suffering, started to develop rough Idle, etc. Not being where I could immediately access a replacement, I pulled the existing one and dumped it out the 'supply-side'..***** was I surprised I was getting anything through it. I then 'back-flushed' it with carbuerator cleaner and reinstalled. It worked great until I got a new one and had the time to install it. I clocked about 200-300 miles before that happened. I now make it part of my annual maintenance.
Old 11-27-2012, 12:17 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
If you car is running smoothly now, you will not get any performance gain by replacing your fuel filter. Keep in mind that after fuel passes through the filter, it enters the fuel pressure regulator. This means that installing a clean filter will not allow gas to flow more freely to the injectors, since the FPR ensures stable fuel pressure, so long as fuel is able to pass through the filter.
On the other hand, if your current fuel filter is clogged and the engine is running poorly as a direct result of that, you will see a "performance gain" (aka: a return to normal).
Here is a DIY tutorial for fuel filter replacement. I'm not sure if the '95s have the filter located underneath or on the firewall, but I think it's underneath (as shown in the tutorial). Others will chime in to clarify.
http://www.dvatp.com/bmw/diy/fuel_filter/
1998 BMW 328is
1966 Pontiac GTO
Old 11-27-2012, 04:06 PM
Thanks a lot guys it's more of a maintenance before it needs to have attention thing for me which Is always best
Old 02-03-2013, 07:25 AM
bm_dubb26 bm_dubb26 is offline
Mein Auto: 1992 BMW 325i
Would replacing my fuel filter on my 1992 325I require the same process??
Old 02-03-2013, 08:38 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Nope. Your fuel filter is located on the firewall (and it's a lot more difficult to get to/replace).
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
