Old 03-11-2013, 06:34 PM
Euro_Hobbs's Avatar
Euro_Hobbs Euro_Hobbs is offline
Euro Convert
Mein Auto: '02 525iT, '93 325is
525iT Misfire/Shudder
Hey guys,
I've got quite a complex situation on my hand so I'll try to describe it the best I can. I currently have a misfire or transmission slip that occurs around 2k from a rolling stop once the vehicle is warmed up.
When cold I get no such hesitation and if I'm moving at a steady speed and give it throttle it's fine.
I first thought it was the TC on it's way out but today I was able to invoke a hesitation enough to trip the SES light and once the light came on it continued to miss until I cycled the ignition or cleared the codes.
I read the codes, cleared them, then went for another drive and was able to trip the light again. Here's the codes that came up:
The OBD codes for cylinder 3 & 5 misfire would come up everytime the SES came on. Now usually I would think if the TC was going I would get an SES for excessive slip or a "trans program" warning but no such thing.
I honestly have no idea where to start when dealing with this issue. I was planning on cleaning the MAF and switching coil packs to see if the problem moves, but the misfire seems to happen at such a specific time, I wonder if it's a complex issue.
Any ideas?
Isaiah 4:12-13
Old 03-12-2013, 05:20 AM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
I start by checking the plug wells for oil. Pull the plugs out and look at them. Then swap coils.
Clear all the codes and take it for a ride, see what comes back.
Old 03-13-2013, 04:04 PM
Euro_Hobbs's Avatar
Euro Convert
Thanks for the reply, I hope to get a chance to check everything out this weekend, my condo will fine me if they catch me doing anything :/
Isaiah 4:12-13
Old 03-13-2013, 05:19 PM
That's why I hated living in a condo. It's just another government!
1. Family control
2. Condo control
3. Government control
4. Religious control
Anyway, back on topic, this thread 'might' help:
- How to diagnose a BMW E39 engine misfire (1)
Old 03-13-2013, 09:10 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Do you get a misfire only at freeway speed when accelerating? I have this & have not found cause.
Old 03-14-2013, 08:44 AM
4thBMW 4thBMW is offline
4th BMW
Mein Auto: 2002 540iT Sportwagon
Mine was a coil problem
I'm doing valve cover gaskets, new spark plugs and plug hole oil removal at 90,450 mi. in order to change my original plugs. I had a multiple misfire flashing SES that coded a #4 misfire. I swapped the #1 for the #4 coil and connector and the code shifted to the #1. Then swapped connectors and the code stayed on #1. Replacing that coil.....and all the spark plugs.
Old 03-14-2013, 09:15 PM
Euro_Hobbs's Avatar
Euro Convert
No, at freeway speeds everything is fine...only at lower RPMs do I get the misfire. It seems to be right under 2k
Isaiah 4:12-13
Old 03-15-2013, 03:04 AM
4th BMW
misfire cylinder
My replacement coil came in yesterday. Installed it on the #1 plug and misfire cured. Mine was running fine at any steady speed. However, when accelerating, like to pass, the engine misfires/ shuddered, flashing Check Engine. Then it started to miss on cold start. Just a coil going bad. Don't over tighten those bolts into the magnesium valve covers.
Old 03-16-2013, 07:35 AM
Euro_Hobbs's Avatar
Euro Convert
Swapped the coils around and the misfire followed the pack, I noticed one of the boots was missing part of the rubber around the bottom too. Do you think the packs are still bad or should I try and replace the rubber first?
Isaiah 4:12-13
Old 03-16-2013, 03:14 PM
4th BMW
swapped coils
Now, swap the connectors. If the misfire stays with that coil....it is the coil. However, if the rubber is bad get a new connector. If you then have 2 coded misfiring cylinders on the two you just swapped, then you have a bad coil on one and a bad connector on the other. Simple deduction.
