E46 (1999 - 2006)
Old 11-28-2012, 02:19 AM
Dathaeus Dathaeus is offline
Mein Auto: 1997 BMW 328i Sports
Shift Knob - Annoying Rattle
My shift knob seems a bit loose, so with the engine vibration, it is a super annoying rattle. I think this I can handle... I want to just pop it off from the stick (I heard its tough but doable), and maybe put some silicon glue in there and then put it back on with some pressure, and I assume that will do the trick?
2003 ZHP 4dr
115,000 miles
Tires: BBS 17" rims
Hankook Ventus V12
Front: 225/45ZR
Rear: 255/40ZR
Answerway.com
Old 11-28-2012, 05:09 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
There are two parts to the manual shift knob. There is an inner plastic liner with a notch in the top that mates with a metal notch in the metal shift lever. This inner plastic liner should NEVER be glued to the shift liner. If it is broken, buy another shift lever. The part that you hand fits over slides over the plastic liner. You may place what ever adhesive you deem necessary there. Personally I found 3M 5200 or Goop works well there.
PT
___________________________________
Old 11-29-2012, 05:29 PM
Yes it was the plastic piece inside.. the knob came off fairly easily, I still have all my teeth, and immediately I saw some loose black pieces of plastic, just removed those, and its all good.... simplest job I ever did.
2003 ZHP 4dr
115,000 miles
Tires: BBS 17" rims
Hankook Ventus V12
Front: 225/45ZR
Rear: 255/40ZR
Answerway.com
Old 12-01-2012, 02:47 AM
Actually after taking those loose plastic pieces out it is still vibrating.... any ideas? Do I need to replace the whole knob?
2003 ZHP 4dr
115,000 miles
Tires: BBS 17" rims
Hankook Ventus V12
Front: 225/45ZR
Rear: 255/40ZR
Answerway.com
