Old 12-05-2012, 09:49 PM
SDBen SDBen is offline
Mein Auto: 335I
coding a 2012 F30 335I
I have a question that I'm hoping someone here might know.
Will a 2.46.3 psdzdata code a 2012 F30 335I? I know someone that coded a 2012 535 with this and didn't know if there is any difference?
Thank you
Old 12-05-2012, 10:44 PM
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
Thank you
It depends on the software version (I-step) currently on the car. 46.3 worked for my April 2012 build F30, but after I took it in and they updated the software, 46.3 no longer worked.
Current is 48.1.
Old 12-06-2012, 08:59 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
As a general rule of thumb, the PSdZData veriosn used with E-Sys needs to be >= to the ISTA/P version last used to program the car. However, you will find in instances where it is < the ISTA/P version, that you can still code many modules but not all. This occurs because not every module on a single chassis gets new firmware with every new ISTA/P version, so the older PSdZData still works on a particular module's older firmware.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
