Old 12-05-2012, 07:24 PM
snowboardjoe snowboardjoe is offline
Mein Auto: 2013 X3 28i
How long to transfer during coding?
Finally got my ENET cable today and ready to start off with a full backup later this evening.
What's the timing for transferring data for a full backup and when making changes? Few seconds? Few minutes? Just trying to get some idea of how long it will take (and how long is too long).
I assume as long as I'm connected to OBD port and laptop the computers will all remain on, right? I have a batter charger I can hook up if needed if it will take some time to do the coding work.
Joe Morris
2013 X3 28i (prem, tech, cold1&2, conv, hud)
Old 12-05-2012, 07:50 PM
cn555ic cn555ic is online now
The Coder guy in N.Y
Mein Auto: bmw
Code the car with engine running...No need for a charger.
Old 12-06-2012, 05:50 AM
Glock 32 Glock 32 is offline
Mein Auto: F10 550i
Take a look at this thread, particularly post #15 and onward:
http://www.bimmerfest.com/forums/sho...d.php?t=653389
I had similar concerns, but it only take a minute or so and you can read them all at once...
Coding only takes a minute or so to edit and code the FDL.
I did not hook up to a charger or run the motor and I did (2) separate sessions and drove the car once in between to test and try to get some more charge on the battery. I made sure to turn off radio, A/C, headlights, DRL, interior light, etc.
You should be fine... I do not like the idea of the charger at least one member said he got errors connecting (i think) when using the charger. Disconnecting the charger seemed to fix his issues...
