Old 11-28-2012, 11:38 AM
D4T_POM's Avatar
D4T_POM D4T_POM is offline
Mein Auto: 2002 E66 745Li
Airbag resistance and resistors
I have airbag sign for my front drivers door and rear left door airbag lights on.
I have taken screen shots of the resistance with INPA and description from DIS.
I wanted to know how many ohms resisters I would need to put in to get rid of the lights.
Tried to PM Stuartjohn regarding this but does not let me attach images on PM's.
Sent from my GT-N7100 using Bimmer App
Old 11-30-2012, 07:52 PM
D4T_POM's Avatar
Sorted some bits of it now.
Thanks Stuart
Old 12-31-2012, 09:04 AM
m3hk1 m3hk1 is offline
IbraCadabra
Mein Auto: Bmw 735
Hi.. Did you manage to get rid of the airbag light? I have the same error but on my rear right door.
Old 12-31-2012, 03:48 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Hi,
Can you read the firing circuit impedances using INPA like D4T_POM has shown above?
Once you know if the circuit is too high or too low you can fix it by adding resistors in series or parallel.
I helped D4T_POM with his a few months back, he dug out a service bulletin regarding the rear door airbags, and the connector between the chassis and door is known to have high resistance issues and the loom is to be replaced.
Of course there are ways around this if you do not wish to retain the airbag functionality, that however is your own decision!
Stuart
Old 01-05-2013, 08:59 AM
IbraCadabra
Mein Auto: Bmw 735
Originally Posted by stuartjohn24 View Post
Hi,
Stuart
Hi! I've done that sometime ago when i wanted to pull out the error codes, took a look and the firing circuit and it was too high. not by much but still.
Since I don't occupy those seats to often and got told that the rear side door airbags are a hazard to children because the airbags are known to break legs and cause serious damage to them. I know there a way to turn them off simply. I've been looking around but no luck.
Old 01-05-2013, 11:28 AM
Mein Auto: BMW F01
Ok, don't think there is a way to disable the airbags through coding.
It is however possible to just wire in a resistor in place of the airbag to make the airbag module think and airbag is fitted.
It's usually done when removing standard steering wheels and fitting racing style ones.
Stuart
2008 F01 - Sophistograu with Saddle Brown Leather
Retrofits:
Night Vision, Digital TV, Heated M-Sport Steering Wheel + Paddles, Combox, 6NF Baseplate, 6NR Apps, Rear Entertainment System, Automatic Boot Close and Surround View Cameras.
Old 01-05-2013, 06:55 PM
IbraCadabra
Mein Auto: Bmw 735
Stuart
Hmm. Thnkx. I will look into it.
Old 03-04-2013, 08:48 AM
kraab kraab is offline
Mein Auto: BMW530i04
To the OP, my airbag in my 530i is resisting just like yours low.
How did you resolve this?
I have tried replacing my battery and clock spring but the error still remains..
ID:	364725   Click image for larger version
ID:	364726   Click image for larger version
Old 08-08-2013, 03:54 PM
Just wanted to let anyone who comes across this thread that my issue was resolved by replacing the steering control module which is part 01 in this link.
I did first replace the SZL and slipring although both of those were a waste of time and money, luckily BMW let me return the parts for the steering module which in turn fixed the dash light and air bag issues!
http://parts.bmwofsouthatlanta.com/s...rimLevel=11894
Old 01-22-2014, 05:31 PM
Muzza Muzza is offline
Muzza
Mein Auto: BMW 745i 2003
Air Bag Light 2003 745i
I have a similar problem to others on here. My Airbag warning light is saying I have a fault with the left rear passenger door airbag. I have had it re-set by computer but it returned the next day. Funny since i have had mt older kids in the bag it comes up? coincidence? lol
