Old 11-27-2012, 07:01 AM
Yaz Yaz is offline
Mein Auto: X3 and 328i Coupe
X3 06 taking little longer to start.
Hello Everyone,
Hope everyone had good holiday
My X3 is taking little longer to start. It not battery problem and its not stater problem because there are no signs of that.
Does that meen I need tuneup? You think it could be because it time for new spark plugs?
It has 60k mils.
Thank you in advance.
Yaz.
Sent from my HTC ONE using Bimmer App
Old 11-27-2012, 08:33 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
its just cranking a little longer before it fires up?
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 11-27-2012, 09:25 AM
Yaz Yaz is offline
Hello
Thank you for your reply.
Yes ...just the way you said, "its cranking a little longer before it fires up"
Thank you.
Yaz
Old 11-27-2012, 10:58 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
Originally Posted by Yaz View Post
Hello Everyone,
It has 60k mils.
Yaz.
Next time you start it turn it to "on" and give it about 10 seconds before you turn to "start". This allows time for the fuel pressure to build up before you try to start it.
If that improves it then it's likely just the check valve in the fuel pump allowing the fuel system to depressurize itself overnight. It's really no big deal if that is what it is. Just pause between on and start. Sometimes it will clear itself of whatever is causing the leak and go back to normal.
Old 11-27-2012, 11:17 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
X2. I just made it a habit to wait until the third "beep"
Also, does it feel slower to crank? like the starter motor turning slower than usual? it could also be the battery letting you know it's on its way out...
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 11-27-2012, 11:36 AM
I tend to do the same on my X3.
I started to do it on my e46 as well but only after leaving it for a couple days without a start.
Supersprint Headers
SuperSprint X-Pipe
Old 11-27-2012, 05:23 PM
Yaz Yaz is offline
Am going to try that for few days and see if that will work or its the battery.
So for sure its not a spark plugs right?
Thank you everyone
Sent from my HTC VLE_U using Bimmer App
Old 11-28-2012, 07:33 AM
Thank you everyone
I wouldn't think the plugs are the culprit.
You might want to run a bottle or two (one at a time) of Techron through it and see if that helps.
Old 11-28-2012, 02:58 PM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
Same here
Ours always has requred more cranking than I felt should have been required. I recently read a thread here regarding waiting a couple seconds after turning the key to position 2. I usually wait until the dash lights start turning off (maybe 3 seconds) and it works for me. Can't tell you why though especially in your case where it was cranking immediately apparently and then all of a sudden it wasn't. Techron, different gas nor a new starter (obtained under warranty) had any impact for me.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
