Old 12-25-2012, 07:12 PM
DavidM1975 DavidM1975 is offline
Mein Auto: 2013 335i sport line
Parked-car ventilation?
Another little interesting tidbit I found in the owner's manual but the description of how it works is very skimpy. Did any of you try this in their F30 yet? The manual mentions you can preset times to activate the system. If the interior of the car is supposed to be cooled down effectively in the summer or warmed up effectively in the winter I understand the car would have to turn the engine on. Can anyone confirm this please?
Old 12-25-2012, 11:57 PM
Kar Don Kar Don is offline
Mein Auto: '14 & '15 i3, now '16 i3
I think this is for the ActiveHybrid model.
2008 Mercedes-Benz CLS550 Iridium Silver/Black Leather -- P2/321/881 (leasetraded 1/10)
2002 BMW 325i --Topaz Blue/Natural Brown Leather --SP/PP/HK/CWP/Bi-xenon (Sold 9/06)
Old 12-26-2012, 07:27 AM
kpgray's Avatar
kpgray kpgray is offline
GasCompression
Mein Auto: 2014 335i M-Sport RWD
No, it does not start the engine. It has two timer settings. On your i-drive, select Menu / Settings / Climate. You will see two timers. Each timer to set the fan start and end times. Set 15 minutes before you get out work to cool the interior off before you get out to your car! I do not know about the heating as I have not tried it for the winter, I may give that a try
Kenneth P. Gray
2014 Black & Tan 335i M-Sport/SAT/PP/TP/CWP/DAP/HK/403M
2010 Cadillac SRX Performance, Platinum Ice/Ebony (Wife's drive)
2014 Black/Tan 335i M-Sport/Sport Automatic Transmission/Premium Package/Technology Package
Cold Weather Package/Driver Assistance Package/Harmon Kardon sound/19" Wheels 403M HP tires
Old 12-26-2012, 07:37 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
It is a ventilation function only. All it does is open the fresh-air dampers and run the HVAC blower; the air is neither heated nor cooled. It will not warm a car that has been parked long enough for the heater core to cool to ambient temperature.
Note you need to exercise a little caution with this feature. For example, if you set one timer for your lunch hour and the second for the end of your workday, and then skip lunch, you might not have enough juice to start the car after work. The owner's manual warns about this (timed ventilation should not be used more than once without driving the vehicle between uses).
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 12-26-2012, 08:04 AM
kpgray's Avatar
GasCompression
Thank you for the insight. I guess the next question is what is the optimal time to cool the interior. Is 5 minutes enough, 10? Has anyone tried?
Kenneth P. Gray
Old 12-26-2012, 08:34 AM
Zeichen311's Avatar
I have always set it for about five minutes before I expect to arrive at the car. That, plus using the Comfort Open feature (press and hold unlock button) to open the windows & roof as I approach the car, seems to be plenty of time even on the hottest days. IIRC the fan runs for at least 15 minutes before it shuts off--I want to say 25 minutes but honestly can't recall, because I haven't used it for several months now. (The time may have changed in the F30 anyway. )
Old 12-26-2012, 11:02 AM
johnofcross's Avatar
johnofcross johnofcross is offline
Mein Auto: F30 335i Superman M Sport
Not sure if you can set the off time, I think it just has two 'ON' times. Here's the OM screenshot. I've set it on 30 minutes before I get to the car, so it's a bit cooler. (FL is hot until winter). It turns itself off after 30 minutes, not sure you can set this to be any shorter.
8/31/2012 ED - ED Report
11/8/2012 PCD
2013 BMW 335i Sedan Estoril Blue II M Sport 2PF|6MT|ZDH|ZTP|Coral Red Leather|688|508
2007 Nissan Sentra SE-R
