Stomp test - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 12-01-2012, 12:33 PM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
Stomp test
Light blinks 20 times? Then repeats
Wicked Fast Entertainment
Old 12-01-2012, 12:42 PM
Go Fast or Go Home
Im thinking vaccum maybe? But then again im thinking because is very very intermittently then because my idle control is bad ( ordered on the way along with a new intake boot) that when the tps senses closed it sends a signal and instead of opening it slaps shut cutting the engine off however when i turn it over it starts right back up
Old 12-01-2012, 01:16 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
If I'm not mistaken, the stomp test provides four digit codes. Your light should start with long flashes of the CEL for the first number, short flashes for the second, long flashes for the third, and short flashes for the fourth digit. The code 1444 means that the ECU does not have any stored fault codes.
Check out this site for a better definition of each fault code. http://e30world.com/fuel/BMW-E30-DME...ic-fault-codes
Big Boyz with Bad Toyz.
