E46 (1999 - 2006)
Old 11-28-2012, 06:27 PM
Blue34m50 Blue34m50 is offline
Mein Auto: 325i 2001, 525i 95
clutch problem
My 2001 325i developed a problem lately after a new clutch was replaced 10 months ago. The car jerks just before I release fully the clutch. Sometime the car shakes a lot and sometimes a little and other times is normal. If I give more rpms before I release the clutch shakes less. Is the clutch disk slipping or is something else? Anew clutch can do that? Thanks for any good ideas.
Old 11-28-2012, 07:34 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Was the flywheel replaced along with the clutch, or is the old one still in there ? BMWs come from the factory with a "DMF" (Dual Mass Flywheel), which occasionaly go bad.
The road goes ever onward....
(R.I.P. Jever)
Old 11-28-2012, 08:10 PM
The flywheel is the original. After I release the clutch the car do not shake at all. Only the moment before full release of the clutch, the car is shaking. Then, I accelerate fast and it has no problem.
Old 11-28-2012, 09:59 PM
Fast Bob's Avatar
Keeping it surreal
Another possibility is a hydraulic problem....try bleeding the clutch slave cylinder.
(R.I.P. Jever)
Old 11-29-2012, 11:51 AM
Finally the problem was solved guys. It was the mid grade gas. I use a high quality gas and so far the clutch works like new. Thanks for your replies.
