Old 11-28-2012, 08:51 PM
danmar danmar is offline
Mein Auto: bmw 2004 530i, 1998 528i,
coolant goes by by
losing coolant, not in oil or leaking. Smoke when start up and after slowing down to stop. It did over heat a bit when rad went out. Thinking head gasket but oil is clean. Any thing else to check before removing head for rebuild ? 1998 528i
Old 11-28-2012, 08:54 PM
wrong car , sorry. 1998 528
Old 11-28-2012, 11:43 PM
Bungcarlo Bungcarlo is offline
Mein Auto: BMW LR Lexus Montero
checked all the cooling system hoses for cracks?
Land Rover BMW 528i Mitsubishi Montero Lexus IS350
Old 11-29-2012, 06:07 PM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
That had my car smoking. I popped the hood and saw coolant shooting out causing smoke. Hang on smokes as in tailpipe or hood
If first you don't succeed you must try again, and then again
Mods
Dinan S1, Drilled slotted rotors, Akembo Pads, 19 in MPars,Zoinsville Super duty kit,
Resident Grammar and Spelling expert
Old 11-30-2012, 07:48 AM
rdl rdl is offline
Mein Auto: 530i 2003
Given the complexity and cost of a head gasket I'd check a few things first, perhaps with help from a repair shop with specialized equipment. Unless I could confirm a head gasket failure between coolant & combustion, I'd look hard elsewhere first. It's possible that the smoke you mention may be a second issue of oil smoke due to valve stem seals or piston rings.
If suspecting a coolant to combusion cylinder leak one can test for the presence of exhaust gases in coolant.
A) One method checks the coolant with strips or test liquid addition to a sample for colour change.
B) Use a tail pipe emissions probe in the throat of expansion tank to test for exhaust gases while engine is running, which should not be present.
C) If you have a sensitive nose, sniff for exhaust smell at the expansion tank, cap off, while the engine is warm and running. But only a few sniffs - be careful of ethylene glycol poisioning.
If chasing a slowish leak, keep in mind that smaller leaks may never leave a drip or wet deposit. The leak can be small/slow enough that the coolant evaporates/dries before forming a droplet, or open only when the system is hot & under pressure and thus lose coolant as a small jet of steam rather than a wet dribble. In either case there is very little indication of the leak point, although BMW coolant does tend to leave a white deposit.
One can use a pressure tester on the expansion tank and look for small leaks, often in a difficult to see obscure corner or hidden location. One can also add ultraviolet dye to the coolant, drive a day or two and then check for dye deposits with a UV light. Again the leak may be in a hidden corner but the UV deposit is ofter easier to find than a liquid seep.
Regards
RDL
Old 11-30-2012, 08:08 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
+1 on what RDL said.
Also, check and see if the gaskets around the WP & T-stat are still OK.
Also, once the car is up to operating temp, I would pull over and pop the hood. If you have a friend, I would ask him to rev the engine as well while you check under the hood. That might show the leak.
Another culprit that will make a car smoke is a failed CCV, which in your case might be coincidental, but making you chase a different demon.
Old 11-30-2012, 03:27 PM
hh3uunp's Avatar
Ball Don't lie
Seems like a head gasket to me. Those 6 cylinders seem more susceptible to headgasket. I don't claim to be an engineer but I will guess it because the 2 headgasket not one
Mods
Old 12-03-2012, 03:00 PM
Water gone within 40 miles and for sure not leak as it would show. Smoke has sweet smell and burns up at speed but not at low RPM. Done head rebuild before on another similar BMW engine so will just tear down and do this one also. Was hoping there was a simple common solution but I needed to ruin a few days anyway,,,,,,,thanks all.
Old 12-04-2012, 01:23 PM
dtadrian's Avatar
dtadrian dtadrian is offline
BMW's are like women. $$$
Mein Auto: 1994 540i
I say get your cooling system pressure tested and take it from there. Report back on your findings
Old 12-04-2012, 03:13 PM
285,000 miles on the engine with nothing but waster pumps and oil changes so unless there is a common leak issue in the intake area I might as well tear it down. Valves will be loaded up with crud by now anyway.
I will update what turns up as I roll along with it.
Old 12-04-2012, 05:43 PM
pshovest pshovest is online now
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
How much coolant are you using and how many miles between additions?
Old 12-04-2012, 05:48 PM
jarhed1964 jarhed1964 is offline
Mein Auto: '99 528i Sport, '05 530i
Dealing with a sudden leak on my 97 right now too. Started literally overnight. Mine is under the intake it appears. Pulling the intake now to try to find it. I suspect the heater return hose. I rebuilt my engine in December and replaced pretty much everything except the radiator and the coolant hoses under the intake.
#5 is what I'm hoping my problem is. Never been replaced. The one on the 99 has though.
Old 12-04-2012, 08:20 PM
going through about 3/4 gal every 50 miles. Just enough to turn on the overheat light. I will check for leaks once more but not counting on it being that lucky because of the smoke when slowing down.
Old 12-05-2012, 07:30 AM
BMW CCA 69606
OUCH!. That's a lot of coolant.
I think you can stop looking for leaks, unless you're smelling coolant under hood.
The good news is you've got an iron block so head bolt threads are OK. Bad news is M52 heads are known to crack on overheat. It would be useful to find out which cylinder is leaking coolant, if possible, before pulling the head. This will help with head inspection. I'd pull plugs and pressurize cooling system, and see which cylinder fills with coolant. HF has a coolant system pressure tester for ~$60. Keep us posted.
