6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
Hi All,
looking for the seatbelt latch assembly for the passenger side..specifically the little arm where the seat belt clicks into, got a coin in it and can't get it out...Can anyone direct me to parts supplier for as new one?? Tried to get it out/but 6 beers later still no good!! Any help would be appreciated! Thanx!! |
Straight lines are for fast cars...turns are for fast drivers '04 M3 - track '06 650i Cab - daily driver '02 Highlander - kid hauler '01 330Ci - winter beater
Can you slip a piece of paper in next to the coin? If so put some double sided tape on it, slide it in with the tape side toward the coin and then push the release button to stick it to the tape and pull it out.
Freedom Isn't Free |
Ok,
will try it out..thanks bebosworth and you too yorgi for the diagram and part numb. |
Sent from my SCH-I510 using Bimmer App |
Hi There,
That sounds like a good idea, however I'm not sure I can see the coin..Will take a look and let you know if your suggestion worked.. Thanx! |
Paper trick didnt work....Got to figure out how to take seat out to get to the seatbelt
latch..Whatever is inside it won't budge.. Thanks all for your suggestions! Blaque47x |
