Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 09-24-2010, 04:12 PM
mbworldz mbworldz is online now
Mein Auto: 2011 740i Blk/Blk
Dinan Tuning for 7 series 750
http://www.dinancars.com/bmw/whats-new
Good news for 750 owner but no news for 740i :-(
Old 09-24-2010, 05:48 PM
Cocodrilo Cocodrilo is offline
Juiceman
Mein Auto: BMW 750i ActiveHybrid
Great news indeed.... Will it work for the activehybrid7? 565 HP?
[/SIGPIC]
Old 09-25-2010, 09:33 AM
That I am not sure. The best way is to call them and find out. This is my first time driving the BMW, I had the Mercedes E63AMG. Tuning using Renntech. They are just one of the best tuner. I heard Dinan is also great and famous on tuning BMW.
Old 09-25-2010, 01:15 PM
Munich77 Munich77 is offline
Mein Auto: 2008 535 xi
For the 740 it should be easy - I suspect that the N54 tuning software would work.
Old 09-25-2010, 01:28 PM
I already talked to couple tuners. The N54 has tons of potentials for tuning than the new n55
In the 740, the aforementioned N54 3.0-liter twin-turbo inline-six is uprated from its previous 335i application by more boost,
to the tune of 10.2 maximum psi. (The increased pressure as well as BMW's greater experience tuning the N54 for higher performance are why the new, single-turbo N55 wasn't used here.)
But even though the N54 engine is same as the new 335 series. Our ECU is little different. So those jb3 software tune will not work for now.
Old 11-06-2010, 04:48 PM
AP24LA AP24LA is offline
Mein Auto: 750i
I realize that this is an old thread but was wondering if the Dinan software would theoretically give the 750 more straight line speed than an Alpina and 760?
Old 11-06-2010, 05:11 PM
huanjf huanjf is offline
UNCBimmer7
Mein Auto: BMW 750Li
doubted. Close to their speed, the most. I am guessing 0-60 around 4.6 to 4.7. I will be getting mine tuned this coming Monday. We will see what difference it will make. I still hesited if the tuning will make the engine sound louder, If that is the case I'd rather not to tune mine car. will call dealer to find out Monday morning.
Dark Graphite Metallic, Oyster Nappa, Camera pkg, Convenience pkg, Driver Assistance pkg, Lux Seating pkg, Premim sound pkg, 19” Wheels/Performance RFT, Leather Instrument Panel, NightVision, Head-up Display, Satellite Radio
Old 11-06-2010, 05:22 PM
Mein Auto: 750i
Might hear the turbo a little more but I wouldnt imagine it would be enough to penetrate the cabin. Keep us up to date. Very interested in finding out the results.
Old 11-06-2010, 05:25 PM
hammadurb hammadurb is offline
Mein Auto: 2009 BMW 750li
"Dinan matches the new car warranty coverage for up to 4 years or 50,000 miles, including the possibility of consequential damages."
I will most likely end up getting the extended warranty and I wonder if Dinan will extend the warranty. The tuning sounds amazing!
"Top Speed Governor Removed. With Dinan’s software, the 750 Li will be capable of achieving its natural top speed as the governor has been removed.
The results of Dinan’s tuning are nothing short of breathtaking, with the added boost and related recalibration producing maximum output of 495 horsepower at 5000 rpm and 573 lb-ft torque at 3500 rpm."
2012 BMW 650i
Mineral White Metallic - Ivory White Nappa - Driver Assistance Package - Full LED Headlights With 20" Style 356 Wheels - Instrument Panel With Leather Finish - Ceramic Controls - Head-Up Display - Luxury Seating Package - Premium Sound Package
12 650i - 03-14-13
09 750li - 05-23-12
06 750li - 10-21-09
03 745li - 10-18-08
00 540i - 12-14-05
Old 11-06-2010, 09:19 PM
texgeekboy texgeekboy is offline
Mein Auto: '09 750i
Originally Posted by hammadurb View Post
...i will most likely end up getting the extended warranty and i wonder if dinan will extend the warranty....
+1
Old 11-07-2010, 03:25 PM
BMW Alpina BMW Alpina is offline
BMW Alpina Enthusiast
Mein Auto: Alpina B7
it could match the Alpina B7 acceleration if you do it once or twice in
short time.
but it might not be able to repeat the same acceleration if you keep doing it
without letting the engine cool down.
because Alpina B7 use bigger cooling pipe, bigger radiator,
larger intercooler, extra oil cooler, bigger radiator fan,
and even the front spoiler of Alpina B7 was designed to channel more cooling air to the engine.
The problem with Alpina B7 is they still use the 6 speed transmission,
while your 750i use the 8 speed transmission...
that mean the 750i should have closer gear ratio and this mean improve acceleration.
I also quite sure that the Alpina B7 is slightly heavier than the 750i (more radiator, bigger wheel,
bigger brakes etc etc)
so this is why I think the Dinan Tuned 750i would be able to match
the Alpina B7 0-60 time, provided that it is done only once or twice in a short period of time.
but after the Dinan Tuned 750i engine temperature gets hotter,
their performance will drop, while Alpina B7 performance will remain constant.
Turbo charge car are sensitive to heat.
oh by the way, Alpina B7 also use larger turbo charger,
stronger Mahle piston,
and Alpina B7 use stronger drive shaft (heavier but stronger).
so Alpina B7 gearbox and differential will be able to handle the extra power with no problem.
(if I am not mistaken, the Alpina B7 have an extra differential cooler... but I am not too sure on this one)
while a Dinan Tuned 750i might experience some problem
if you keep on driving it hard all the time.
I actually think that with all those stronger driveline and 6 speeds gearbox,
the Alpina B7 should be able to handle even higher power...
and Alpina B7 had bigger turbo so, I think Alpina B7 can have higher boost pressure, but if they maximize the power,
it will eclipse the power of the 760i and this is not good for BMW.
hmm.. Alpina B7 also use different method to reduce engine power between gear shift, so Alpina B7 have faster shift time
compare to regular 750i, but this is only millisecond in difference...
I think the Dinan 750i tuned is good value for money,
but it might not be as reliable as an Alpina B7.
Old 11-07-2010, 04:29 PM
Copasetic22 Copasetic22 is offline
Mein Auto: Cayenne TurboS, BMW M5 S2
Actually the 760 uses the 8 speed tranny, but the 750's still use the 6 speeds.
Old 11-07-2010, 06:01 PM
Mein Auto: 750i
short time.
Great info, thank you very much. I am definitely not planning on tracking the 750 so repeated runs or overall agressive driving won't be an issue. I just want to know that when I step on it it will move with an s63, s8 etc.
Old 11-07-2010, 09:38 PM
I see,
Thanks for the correction.
but I was googling (in a quick glance),
and I open a website (not official BMW website)
that have active hybrid 750i spec,
and it show that car (the active hybrid) use the 8 speed,
so I assume other 750i use 8 speed.
apparently I am wrong,
I should have open the BMW website directly for more valid info.
my mistake...
Old 11-07-2010, 09:58 PM
I see,
my mistake...
No problem. Wish you were right!
Old 11-08-2010, 04:08 AM
I think you are right. The Alpina is purpose built to be a high speed performance car and I think outside of the US, a large share of the Alpina clientele drives the car to its capabilities. Alpina upgraded all aspects of the engine to achieve the higher performance. I think to achieve that performance, the B7 also runs at a higher pressure.
A dinan tuned 750 will offer great performance but does not have the additional safety precautions that Alpina put into the engine. I think that long term both cars should be just as reliable especially in the US. Most of the time, even a tuned 750 will operate within conservative operating parameters. Plus unlike other tunes, Dinan takes a complete approach. I know for the N54 and I suspect also for the 750, Dinan also changed the programming of the cooling system providing the engine with more cooling.
Old 11-08-2010, 03:39 PM
UNCBimmer7
Dinan Tune update:
NO GO!!!!!
Drove 2 hrs+ back and forth for nothing. Dinan tune is only available for 750i so far. WTF, Dealer just sucks for not telling me upfront. I told them my car model and all that, setup an appointment, when I got there, they kept me waiting for 30 mins and then came out telling me it will only be available for 750i so far. Really pissed off today.
Old 11-08-2010, 07:43 PM
Juiceman
Just got words from Dinan that for the AH7 the tune will not work. Only the 750.
[/SIGPIC]
Old 11-08-2010, 10:14 PM
Dinan Tune update:
NO GO!!!!!
"Luxury + Power = Amazing combination. Welcome, the Dinan Stage 1 Performance Engine Software for the BMW 750 Li."
This is directly from their site. It states specifically for the 750li!
I was going in tomorrow to get more info on the warranty issue, I will find out what they say. I might just contact Dinan directly and see what they say.
2012 BMW 650i
12 650i - 03-14-13
09 750li - 05-23-12
06 750li - 10-21-09
03 745li - 10-18-08
00 540i - 12-14-05
Old 11-09-2010, 02:43 AM
Dinan Tune update:
NO GO!!!!!
Strange, the750i and 750iL only different is the rear suspension,
where 750iL is self leveling...
the engine is the same...
maybe your dealer do not understand well...
better contact Dinan directly for clarification.
Old 11-09-2010, 06:24 AM
UNCBimmer7
I feel fishy too. I have already contacted Dinan, left a message and emailed regional sales rep. Waiting for their reply. I I will keep you guys updated.
Regarding the Warranty. I have asked the BMW dealer, they only cover the original warranty, if you have 4 years than they cover 4 years, but if you got the extended warranty when you bought your car, then they will honor the extended warranty.
Old 11-09-2010, 06:44 AM
mdrbuy mdrbuy is offline
Mein Auto: 2011 750Li ActiveHybrid
If they do a tune for us (AH7) Cocodrilo, then we will have a beast beyond compare.
Old 11-09-2010, 08:19 AM
UNCBimmer7
It will turn your car into a Lux Race Car.
Old 11-09-2010, 10:55 AM
UNCBimmer7
Update:
My "local" (60+ miles from where I live) dealer, whom I went to yesterday had a miscommunication with Dinan Sales Rep. They thought my car is a X-drive. 750Li and 750i, both car a OK for tuning. I could not do it anyway yesterday, since the dealer needs a special ethanet cable. This cable is only good for 750 dinan software upload. They used to dinan tuning other model BMWs with a different type of Cabel. As I mentioned, I'm the first 750 owner requested this tuning. For all the trouble I went though, it's better worht it.
Old 11-09-2010, 12:44 PM
Update:
Good luck. I think it will be worth it. Most people with the Dinan tune for the N54 are very happy. So I think that it will be the same for this engine.
