Old 10-02-2012, 09:09 PM
vstM3's Avatar
vstM3 vstM3 is offline
Mein Auto: F80 M3
Winter tire package -- 335is
What tires/rims did you guys get or planning to get for winter? Thanks for sharing!
I saw on another post a suggestion: leave your car in the garage (protect it) and get a used xdrive for about 10k...that's more expensive than getting winter tire package but what do others think?
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is
Other: 2014 Mini Cooper
Old 10-03-2012, 02:50 AM
floydarogers's Avatar
Pedant and Curmudgeon
I'd get 7.5" or 8" x 17" rims and 205/50 or 225/45 R17 winter tires
Old 10-03-2012, 03:19 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
225/45-17 Blizzak WR-70s on Rial Salernos. Going into my 6th or 7th winter on Blizzaks.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 10-03-2012, 10:40 AM
vstM3's Avatar
Mein Auto: F80 M3
The 335is comes with 19" wheels, why not putting 19" wheels with winter tires?
Old 10-03-2012, 11:00 AM
DSXMachina's Avatar
Bimmerdex 7.4!
You can't go wrong with real snows from Conti, Michelin, Blizzak or Nokian.
I have Blizzaks and just ordered the Michelins for the 335. I have Conti Winter Force for my Saab Aero.
Best tire value for the money? Nokian if they're sold in your area.
Old 10-03-2012, 11:37 AM
Because it's very hard to find winter tires in 19" size. Because 17" is far less expensive. Because narrow tires are better in winter than wide. Because you can find a much larger selection in 17". Because you can even find true winter tires (non-speed rated) in 17" while with 19" you're stuck with speed-rated high performance snows that are more suited to roads than snow. Because 19" tires with short sidewalls suck when hitting winter potholes. Because you can fit chains/cables to 17" narrow tires.
Old 10-03-2012, 12:24 PM
vstM3's Avatar
Mein Auto: F80 M3
Will they fit with no adjustments? Snap off the 19"" and put 17"?
Old 10-03-2012, 01:06 PM
fordperf fordperf is offline
Mein Auto: 2009 335xi LCI
My 2009 335 came with 17"
Old 10-03-2012, 01:25 PM
beden1's Avatar
beden1 beden1 is offline
Mein Auto: '11 E93 335is & '08 535xi
I don't think 19" snow tires will fit in the wheel wells. My RFT ultra low profile summer tires look like rubber bands in order to fit.
The max size I would go with is 18".
Old 10-03-2012, 01:43 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
obviously you'll need 17"rims. but 225/35/19 and 225/45/17 are both ~25.0" in diameter, so no other changes needed.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 10-03-2012, 02:32 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Did you use the TireRack tire sizer app? Very handy thing.
Old 10-03-2012, 02:35 PM
i do my tire math in my head
Old 10-03-2012, 02:49 PM
vstM3's Avatar
Mein Auto: F80 M3
Ok thanks. I did not realize the diameter is the same for 17" and 19" wheels.
Old 10-03-2012, 02:51 PM
vstM3's Avatar
Mein Auto: F80 M3
Does anybody want to share pictures of their winter tire package and how it looks on their car?
Old 10-03-2012, 07:45 PM
DSXMachina's Avatar
Bimmerdex 7.4!
It isn't neccessarily, but it is in the example given. It all has to do with the aspect ratio of the tire, it changes the distance from the bead to the ground. The less the distance, the less the diameter.
Old 10-03-2012, 07:51 PM
Zooks527's Avatar
From 3 years ago. 225/45-R17 Blizzaks on 17" Rial Salernos. Includes extra road salt.
Old 10-03-2012, 07:52 PM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
were gonna put 225/40-45R17s on our 2007 335 convertible. Blizzaks all the way, wrapped around some Elbrus 5 spokes
Old 10-03-2012, 08:17 PM
this.
for the 19" tire:
225 X 0.35= 79mm ~3" sidewall. 2 x 3"= 6 +19" =25"
for the 17" tire
225 X0.45 =100mm ~4" sidewall. 2 x 4"= 8 + 17" =25"
in a tire size, the first number is the tread width.
the second number is the sidewall ratio (what percentage of the treadwidth is the sidewall height)
third number is obviously the rim size.
general rule of thumb is to go down 0.05 for every 1" of rim assuming the same treadwidth
Old 10-03-2012, 09:13 PM
jummo's Avatar
jummo jummo is offline
False Enthusiast
Mein Auto: 14 435xi 14 X1 35i
Since my snows are on from mid October till the end of April every year and most of my driving is during these months I wanted tires and wheels that handle reasonably well.
My wheels are 18" Sparco Pista's with Dunlop Winter Sport 3D's 225/40/18.
I have 2 winters on them (25,000 miles) and am hoping to make it through this winter.
jummo
"I know you were offended, but jummo's advice was sound."
Old 10-03-2012, 09:23 PM
jummo's Avatar
False Enthusiast
Here's a picture.
Name:	bmw with snows.jpg
Old 10-04-2012, 05:25 AM
demontwinz demontwinz is offline
Mein Auto: 335 E92
those are nice Jummo
I just got my 335i 1 month ago.
I have 18" Pirelli Pzero Nero M + S all seasons
i was hoping to make it through our Canadian Winter .. am I too naive?
I am new to the forum btw .. i love it here : )
Old 10-04-2012, 05:39 AM
Kief's Avatar
Kief Kief is offline
Mein Auto: 2017 F80 ///M3 ZCP
I plan on using these from my Z435is....
18" Sport Edition KM-11 w/Conti DWS--yes, I know not dedicated winter rubber, but these work well for my needs and I use my X5d on the really bad days
ID:	344290   Click image for larger version
ID:	344291   Click image for larger version
2017--F80 ///M3 ZCP
2016--F-Type Coupe R*
2015--F15 X535i
2015--F82 ///M4 [ED 6/26/14]*
2015--V60 Polestar (#62:80)*
2012--E92 335is*
2011--E70 X5d*
2011--E89 Z435is*
2009--E89 Z435i*
2008--E92 335i [ED 2/23/08]*
2007--MkV GTI*
2006--R53 Cooper S (JCW) 6MT*
2006--E90 330i*
2005--E83 X3*
2004--E83 X3*
2003--E46 325Ci*
*retired
Old 10-04-2012, 05:58 AM
DSXMachina's Avatar
Bimmerdex 7.4!
You have my car! Return it at the earliest opportunity and all is forgiven.
Old 10-04-2012, 12:20 PM
Kief's Avatar
Which one?
2017--F80 ///M3 ZCP
2015--F15 X535i
2012--E92 335is*
2011--E70 X5d*
2011--E89 Z435is*
2009--E89 Z435i*
2007--MkV GTI*
2006--E90 330i*
2005--E83 X3*
2004--E83 X3*
2003--E46 325Ci*
*retired
Old 11-30-2012, 01:03 PM
Ilove3er Ilove3er is offline
Mein Auto: '10 335xi coupe
Hello. I am picking up a 335is in a week and looking to get 17 inch wheels for it for winter tires that I have from my current 335 (225/45R-17 Bridgestone Blizzak LM-60 from TireRack ). I read that one has to be careful with choosing 17 inch wheels for the 335 with sport package or 335is because of the possible brake clearance issue. I looked on Tire Rack for the available wheels for the 335is and found a variety of 17 inch wheels that as I understand Tire Rack knows will fit the 335is. I wanted to ask for some guidance on choosing a set of wheel. I was looking at the cheapest that was available, about $100 per wheel If I were to get the black painted wheels, is black paint somehow more prone to discoloring or chipping? The cheaper the wheels the worse quality? Can someone please share their knowledge on selecting wheels?
Also, as I understand I have to get the TPMS sensors for the new set of wheels?
Any feedback is appreciated.
Thanks.
