Old 09-22-2010, 04:13 AM
Jasonau01 Jasonau01 is offline
Mein Auto: BMW 645ci
Dynamic drive failure
Anyone had experience of this??
Will this be a costly fix ??
Old 09-22-2010, 05:00 AM
six_four_five six_four_five is offline
Mein Auto: 645CI
ive had this error come up 2 or 3 times ever since ive owned the car (ive owned it for 4months now) and it went away on its own. I dont know if this is a good thing or a bad thing? help please?
1. 2004 645ci blk on blk coupe:
- 50% tint all the way around
- 22" Maya MRS 3 piece wheels
- magnaflow full catback system
- k&n filter
- All lighting is aftermarket...no stock bulbs!
- euro overlay
- tinted tails
2. 2006 Acura TL blk on camel - too much to list
Old 09-22-2010, 08:30 AM
DBLAZE's Avatar
DBLAZE DBLAZE is offline
Mein Auto: Alpine White F01 750i X
I saw this in the manual while I was reading yesterday, and it says to pull over and restart the car to re-initialize the system. If it doesn't go out on its own after that, then you have a serious malfunction. If it disappears then you should be ok. If it stays on, then you have to go to the stealership.
BMW F01 Alpine White 750i xDrive; Oyster Interior
[BMS Stage 1 Tune | VRS Front Spoiler | AC Schnitzer Trunk & Roof Spoilers | AC Schnitzer Pedals/Footrest | 45% Tint]
BMW E63 Jet Black 645ci - Retired
BMW E46 Fern Green 323ci - Retired
Old 09-22-2010, 02:29 PM
Mein Auto: 645CI
thanks for ur help dblaze...stealership haha i like that one
- k&n filter
- euro overlay
- tinted tails
Old 09-23-2010, 12:47 PM
vpett vpett is offline
Mein Auto: 645ci
Angry dynamic drive failure
I was told by the dealer that it would cost 3,000 for the part not including labor he said that i should get rid of the car , four months after they sold it to me.
Old 09-23-2010, 11:49 PM
jusbo jusbo is offline
Mein Auto: 2016 120d xdrive m sport
You should check the hydraulic oil level, the one behind the coolant with CHF11S oil only written on it.
My 645ci went twice to dealer and they didn't notice it, after I topped the oil, I haven't got that error anymore.
Old 09-24-2010, 12:31 AM
Jusbo: where to get that oil???
Can u post a picture of the oil n the location of the lid???
Old 09-24-2010, 05:46 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Here in the US the 11S fluid can be easily had from the major auto parts stores. Not sure if you can get it in HK Jasonau01 like that but it seems its readily available.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 09-24-2010, 11:10 AM
Here is the oil reservoir, it should be checked at 20 celsius degrees temperature and there is maximum level in the dipstick that is attached to the oil reservoir cap.
My car's oil reservoir was totally empty, there was oil only left in the pipes. I got that error on hard cornering in cold mornings.
You should be able to get the oil, if needed, from auto parts stores or BMW dealer.
Old 09-24-2010, 01:23 PM
Mein Auto: 645CI
CHF11S is the type of oil?
- k&n filter
- euro overlay
- tinted tails
Old 09-24-2010, 01:33 PM
pablo645's Avatar
It's a Hydraulic fluid. Greenish in color. It comes in a green can I believe.
Previous Cars:
Old 09-24-2010, 02:55 PM
amcrae's Avatar
amcrae amcrae is offline
Mein Auto: 2005 BMW 645 CI
thats power steering fluid mostly likely u can only get from the dealer the cost is 40.00 or u can go to the dealer and they will top it off for free had my 05 645 ci done today
Old 05-21-2014, 06:56 PM
jb43saints jb43saints is offline
Mein Auto: 645ci e63
I have a 2004 645ci with 30,000 miles. my dynamic drive malfunction light comes on twice a week then disappears in a few seconds without doing anything. Any advice on this? Thanks
Old 05-21-2014, 07:23 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Have you checked the power steering fluid level?
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 06-29-2014, 12:25 PM
Samuil49 Samuil49 is offline
Mein Auto: BMW 645 Model 2004
Hello Everyone. Please anyone who knows help me out. I have a 645 ci model 2004 I have a problem of a dynamic failure in my car. I took it for fixing oil leak and it came out from the garage with that problem. The car is not balanced. One side is slightly up
Old 06-29-2014, 12:27 PM
anyone knows what's the problem? Is it a major thing?
Old 06-29-2014, 09:29 PM
Yorgi's Avatar
It sounds like you have a pretty serious failure if one side of your car is higher than the other due to a dynamic drive issue. Hopefully it is not a faulty valve block which is a very expensive part.
I would be suspicious that the problem occurred after bringing the car in for an oil change. Maybe they accidentally cut a hydraulic hose or disconnected a stabilizer bar or end link? I would start by asking the shop to take a look at it since it happened after they worked on the car. Also check your power steering fluid level to see if it's low.
Here is an example of how much the dynamic drive can lift/lower the car - this is a diagnostic routine that can be run using DIS:
'04 M3 - track
Old 06-30-2014, 03:31 AM
yorgi. Took it to the bmw dealer and their mechanics told me its a faulty valve block. I guess its going to be expensive fixing it. Checked the power steering fluids level is ok not low.
Old 06-30-2014, 11:53 PM
645/333's Avatar
645/333 645/333 is offline
Michael
There is a post or a DIY where a guy repairs or replaces a valve block, lots of pictures etc It maybe on the 7 series forum or the 5 series but if you do a search you will find it?
It may help in your understanding of the issue and so you don't get ripped off.
As Yorgi mentioned it is a very expensive repair in parts and labour. The guy who did the DIY saved a small fortune.The valve block is behind the front wheel behind a panel in the wheel arch.
Old 07-01-2014, 05:20 AM
Yeah, that bill can run $1700 to $2000 at a dealer. Find an independent, of if you are a DIY'er then here is the thread that 645 is talking about
http://www.bimmerfest.com/forums/sho...46#post5123046
Old 07-04-2014, 08:45 AM
Hello There, anyone knows where I can get headlights even afyer market for mu BMW 645 model 2004 ?
Old 07-04-2014, 10:04 AM
roseng's Avatar
roseng roseng is offline
eBay
Old 07-04-2014, 12:11 PM
sentrex sentrex is offline
Mein Auto: 645ci convertible 2004
well that is pretty cool diddn't you could test that ty
Old 07-06-2014, 12:15 PM
HerbP HerbP is offline
I found this in my files. I do not believe that the hydraulic block could fail, but another part in the system is most likely bad? A valve block is simply a block of metal, with orifices & sensors to control the hydraulic system. The system could have trash, air, or a restriction, causing a problem in the system.. A BMW shop is not going to try & repair the block, due to the time & cost associated with it. A independent repair shop, might be willing to test & repair the system. Read this document for a full explanation of the system. Without someone helping with the proper troubleshooting software ( DIS ), it would be very hard to figure out? As Yorgi stated, find out what the repair shop actually worked on? If they replaced a leaking line on the hydraulic system, it would have to be bled, & run thru a new commissioning.
One last question is, have you measured your battery voltage under the hood? Low battery voltage, or overcurrent, will cause the system to be disabled. If the ECU measures a voltage above or below 5 volts DC, it will start trying to protect the control modules. Your system sound like a failed component, but checking the voltage does not cost anything. Troubleshooting this system will be quite the challenge!
Hope this helps!
Old 08-06-2014, 07:38 AM
Dynamic Drive Malfuction
Yes the level is fine. I took it to the nearby repair service and they couldn't find anything so they decoded the error message. It was good for about a month and a half until it came on again. So confusing!
