E46 (1999 - 2006)
Old 11-29-2012, 01:36 PM
Farmgrrl Farmgrrl is offline
Mein Auto: 323i
Fuel Level Sensor question
I have a 2000 323i. I noticed a few weeks ago when I filled up, it fuel gauge did not show FULL. It showed only 3/4 full. After driving for a while, it slowly went to where it needed to be. The next time I filled up, it was the same thing. However, the time before last, after filling up, it stayed at 3/4 and then the next day, dropped to half. The "miles to empty" corresponded with the fuel gauge. I decided to rely on my trip meter to let me know when I needed to fill up. When I had driven to what my calculations would equal about a 1/2 tank, it seemed that the fuel gauge appeared to be working again. Still relying on my trip meter, I drove about another 75 miles, and the fuel gauge seemed to be okay.
Well, the last time I filled up was yesterday. Same problem as the time before. From what I have read on this forum, it appears that fuel level sensor on the driver's side is going bad and/or my husband needs to check the wires (the fuel pump was replaced in August). My question is, until I can get this fixed/looked at, if the fuel level sensor goes completely out and the fuel gauge shows empty, but I know that I have fuel in the car, will I still be able to drive it? I don't want to get stranded somewhere because the fuel level sensor went out and since the fuel gauge shows empty, the car stops running.
Any advice/response would be greatly appreciated!
Old 11-29-2012, 02:15 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Car should drive fine. Just fill it up and keep track of the miles driven since fill up. If the gauge stops working, fill up every 200 miles and you should never run out of gas.
Old 11-29-2012, 10:53 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
+1
You'll have no problem. Gauge only function is to let you know the fuel level.
