Old 11-29-2012, 04:00 PM
glaz1281's Avatar
glaz1281 glaz1281 is offline
Mein Auto: bmw 530i
Passenger side brake light
I having a problem with my brake light. When I turn the bulb holder all the way and it clicks in it goes out. If I dont turn the holder fully the light works .Ive tried different bulb holders. Could it be the part that the bulb holders twist into.??? Anyone with a similar problem? All replies apppreciated.
O2 530i Titangrau metallic/Grey interior.
Old 11-29-2012, 05:23 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
are you referring to the middle brake light?
"And if you no longer go for a gap that exists, you are no longer a racing driver because we are competing, we are competing to win."-Senna
Old 11-29-2012, 05:24 PM
bkgreene39's Avatar
Third stop lamp?
Old 11-29-2012, 05:51 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
You will need to get in there with a flashlight and look at the tail light more closely. Are you absolutely positive you have the correct bulb? If bulb holders from the other side don't help, then the tail light mating surface maybe messed up. You might be able to fix it up, but you may also need to replace the tail light assembly. Factory tail lights are not cheap...
540 M-Sport package (Canadian market), factory Bluetooth phone kit, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, H&R 15mm spacers, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 11-29-2012, 06:03 PM
glaz1281's Avatar
Mein Auto: bmw 530i
I have access to a pair of tail[ghts.Also it is not the third brakelight.Thought someone may have had a similar situation. Thanks
Old 11-29-2012, 06:27 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Did you try swapping the backup light to the brake light position?
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 11-29-2012, 08:44 PM
glaz1281's Avatar
Mein Auto: bmw 530i
I didnt really have time to diagnose yet. Athough I did switch some bulbs and sockets from the drivers side. I believe its the housing. Ill check real oem.
Old 12-04-2012, 07:24 AM
glaz1281's Avatar
Mein Auto: bmw 530i
Problem solved,The brake light housing had a bad socket connection,the metal was bent making for a bad connection. .Switched it out with another housing .All works fine now.
