Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 11-29-2012, 04:15 PM
zachiepie zachiepie is offline
Mein Auto: 1997 328is, 2001 750is
Broken key fob
The dude who owned the car before me dropped the key once, cracking the body and losing the unlock button. I've seen fob bodies on ebay (from china and such), but that just seems iffy. Places like pelicanparts don't even carry them.
Is the dealer the only choice for me?
Old 11-30-2012, 06:40 AM
BMWFatherFigure's Avatar
Old School
Just about. Sorry.
Current:
Previous:
Old 11-30-2012, 12:53 PM
Rats.
Old 11-30-2012, 11:01 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
If the electronics all still work, just get one of the empty cases for 8-12 bucks on Amazon or fleaBay and swap the guts over. They actually have pretty good reviews and I'm planning to do that for my E38 key that could use a freshening.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 12-01-2012, 07:52 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Agree with E36phantom. If the key is still starting the engine, just buy the body. I changed the buttons on my key, I ordered from Ebay, China to be more specific, free shipping for $5. It's true that it took 2 weeks until I got them, but they matched. Buttons only.
JOY = BMW
Old 12-01-2012, 12:59 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
If taking the route of buying a generic "new style" diamond-shaped key case & blade...first make sure that you have a local keysmith that has the equipment to cut the blade (its not like a simple house key). Secondly, make sure that you buy a blank that has the correct key blade. Not all blank keys sold on eBay have the correct blade for our style of keys. And third, make sure that you buy a key that has the correct RF frequency (315 MHz in the USA...433 MHz in Europe and some other markets). If the RF doesn't match...the the FZV/DWA receiver in the C-pillar won't receive the signal to lock/unlock central locking system & arm/disarm the car's alarm siren system.
Some of our key blades are similar to a sandwich...the section in the middle (the meat) remains solid and uncut...and the top & lower halves (the bread) are the ones that get cut. There may also be a notch cut into the blade near the head of the key. While some key blades are solid from the head to the tip of the blade...and the middle of the blade is cut-out on each side.
Also remember that many blank key vendors on eBay falsely indicate that you can get a BMW dealer to initialize the key to start your car...THAT IS INCORRECT. A BMW dealership has no way to program the EWS transponder inside the key to start your car. As far as programming the key to lock/unlock & arm/disarm (FZV/DWA) your car...you can do that yourself following the instructions that have been posted here and every other BMW forum. Your key contains a transponder that is SPECIFIC to your car and has an ISN (individual serial number) that is assigned to it as well as your EWS control module and DME/ECU. So ALL of the guts/innards of your key will need to be transferred over into the new blank key case.
Good luck.
Q {BMW CCA Member #191509}
(SOLD)
Old 12-01-2012, 02:11 PM
wattbmw wattbmw is offline
Watt
Mein Auto: Black, 2000, 740i
What is the typical cost for a new keys at the dealership?
Old 12-01-2012, 04:26 PM
QSilver7's Avatar
There are several types of keys available...and each BMW dealership sets their own price...but in the list below...you can see the general MSRP and what this particular dealership sells each key for:
  1. 3 button remote key (old style & new style...you can only purchase the type your car came with)
  2. illuminated key
  3. general/spare key (metal blade)
  4. wallet/spare key (plastic)
  5. valet key (gray head & only operates the door & ignition...it won't open a locked trunk or glovebox)
(check back if the image doesn't appear...the server it's stored on is having maintenance issues and may sporadically appear/disappear)
(SOLD)
Old 12-01-2012, 04:35 PM
Nice info Qsilver. Can't imagine how many cars you've broken into with all that knowledge!
The advantage I have is that the innards work, so I just needed to transfer cases. I was just worried about them not fitting or whatever, but I'll give it a shot and let you know how it goes.
Z
Old 12-01-2012, 07:33 PM
Watt
My keys work, but just thinking about getting new ones and checking options.
Old 12-02-2012, 11:27 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Dunno what the key looks like for the E38, but these E39 links may provide useful hints for replacing the key body if yours is similar:
- How to replace the old-style BMW E39 square key battery (1) (2) (3) & how to replace the rubber key pads in the old style square keys (1) (2) & opening, charging, recoding, & battery replacement (1) of the new-style diamond key (1) (2) (3) (4) (5) (6) & how to recharge off your BMW and how long a BMW key will last in the drawer before it needs that off-the-car recharging (1) & converting the old-style square key to the newer diamond shaped key (1) & the details on swapping the BMW diamond key transponder (1) & proper diamond key initializing (1) (2) & what to do if your key is locked inside your bimmer (1) & a description of the various types of BMW Remote, Illuminated, Spare/Wallet, & Valet/Service keys (1) (2) & a list of diamond key EWS, FZV, & DWA functions (1) (2) & all about the 10-key limit to programming your own keys at home (1) & a description of the ignition key ISN (individual serial number) ten-second rule (1) & what to do if you lost your only diamond key (1) or what to do if your BMW key was stolen (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 12-02-2012, 09:05 PM
QSilver7's Avatar
The e38/e39/e46/e53 are all generational siblings so things like "keys" are basically the same style. And if there are other models that were being produced during the 1995-2006 era that was from another generation (like the e36 & Z4) and used the same communication bus and keys...all of the info you posted will apply.
(SOLD)
Old 12-03-2012, 07:00 AM
bluebee's Avatar
Great!
Most of the best key information came from you in the first place!
So this user is in good hands!
Old 12-03-2012, 02:57 PM
Great!
Waaay more than what I needed, but I suspect I'll come back to this post MANY times!
Old 12-04-2012, 11:34 AM
Watt
I can't thank you enough for the info. I will likely purchase from this info.
HTML code is Off
