335is or an M3 - Page 9 - Bimmerfest - BMW Forums
Old 04-14-2013, 10:46 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
I think COBB was a little late putting an IS specific tune together so published dynos might be a bit harder to find. FMIC will not do much to add to the cars power but it will help the car keep what power it does have.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 04-15-2013, 08:02 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by vst335is View Post
And not that you do need more power but if you do, spend under $1000 and you're above what M3 can do.
Whaaa? Can't never put no power down -nor- go 'round no corner fer <$1k like M3. Can't even change no lane.
But.....fer maybe skosh more, can install meth....
Old 04-16-2013, 07:21 PM
isjoey isjoey is offline
Mein Auto: 2011 335is
Originally Posted by CALWATERBOY View Post
That's true unless the 335i has the sport option. Then, identical.
BMW Performance Suspension can't never be real good 'cause:
  • Progressive Springs
  • Lacks LSD
  • Oil filled rubber bushings
  • Lower performance rear subframe bushings
  • Spaghetti thin rear sway
Better then "Sport", not as good as a home made M3 suspension build, ultimately only as good as the driver in the end.
2017 M2 Alpine White | DCT | M Performance Exhaust
2011 335is | M3 suspension bits all around | Ohlins R&T | Vorshlag camber/caster plates | Wavetrac LSD | Goodridge PTFE SS brake lines | Apex PS-7 wheels
Old 04-16-2013, 08:07 PM
  • Lacks LSD
Did we ever find out if the 335IS has the rumored improved subframe bushings?
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
