Old 11-29-2012, 06:53 PM
azaps4890 azaps4890 is offline
Mein Auto: 2003 525iT 1976 2002
P0313 after prolonged idle
Hi.
I know that this subject was probably already discussed somewhere, but never found a remedy for my specific issue.
Everything is fine, until car sits and idles for a few minutes. Engine will start running rough and check engine light comes on. I would turn it off and back on - runs just fine.
Already checked DISA, cleaned idle valve and whole intake, replaced iffy hoses and rubber.
New fuel filter as well. Car has 105K miles. Can it be an old fuel pump?
Thanks,
Eric
Old 11-29-2012, 08:19 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Get a fuel pressure gauge and observe the pressure when it occurs. You have a Schrader valve on the fuel rail which makes it easy to attach a gauge.
Get thee to Harbor Freight and buy the kit. Pressure s/b 50 psi+.
Old 11-30-2012, 11:39 AM
Thanks. I'll try that.
What baffles me is, that if it's a fuel pump - then the problems should appear when the demand is high (high RPM) versus low (idle).
Eric
