Oil Pipe Oulet Anyone done this this repair? - Bimmerfest - BMW Forums
Old 11-30-2012, 10:41 AM
nomoexes nomoexes is offline
Mein Auto: E38 740il
My oil pipe oulet hose is leaking. This is the hose the extends from the Oil Filter mount down to the Oil Pan. There seems to be a ton of stuff in the way. Has anyone done this replacement hose. Just looking for a procedure. Thanks!
Old 11-30-2012, 08:38 PM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
I changed that in the past. You need to remove power steering, left engine mount bracket, jack the engine couple inches up. Change the O-rings (#7) here in the diagram http://realoem.com/bmw/showparts.do?...14&hg=11&fg=30, and you are done. Use a torque wrench when you are tightening the engine mount bracket back.http://realoem.com/bmw/showparts.do?...00&hg=22&fg=05
JOY = BMW
Old 01-07-2013, 06:17 PM
Thanks greatly
You guys rock
HTML code is Off
