Old 02-13-2013, 06:54 PM
528i's Avatar
528i 528i is offline
totally
Mein Auto: ist schwarz
Just had an Inspection 2.. Questions about some faults
So I picked up my car after hours, the shop made a note of a few faults, and I hoped you folks could shed some light. Written as is:
FAULTS:
Secondary air system
relay
Currently not present
Fault frequency 1 time.
AUC sensor is faulted
Oil level sensor is faulted
multiple supply voltage faults
I did a search like a good boy and found a solution (I think for the AUC sensor), and this video makes replacing the oil level sensor easy:
though I'm not sure how willing I am to drain all the oil to get to that point.
I am confused on the secondary air system and "multiple supply voltage" faults.
Are these things I should have them retest? Maybe a bad battery?
Old 02-13-2013, 07:16 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Or you could check your oil on a regular basis. Mine has been throwing that fault for over 150,000 miles.
Either you are part of the solution, or you are part of the problem.
Old 02-13-2013, 09:13 PM
ian@jewelorjalopy ian@jewelorjalopy is offline
Past Sponsor
Mein Auto: 2000 540it Sport - sold
Or wait until the next oil change, drain the oil, replace the sensor, done.
I can't help much with the other faults.
Old 02-13-2013, 11:33 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
We are generally conversant with P-codes. Based on your notes, it will be difficult to help.
If you plan to troubleshoot/repair this car, best get a scan tool and the Bentley manual. This is not a '56 Ford.
Old 02-14-2013, 04:42 AM
JimLev JimLev is offline
What year 528, the build date is on the drivers door post? You may not have a secondary air system. If you don't have the CEL on then I wouldn't loose any sleep over this.
If everything is working OK I'd clear the codes and see if any come back, they could be old codes that were stored in memory.
