Old 12-13-2012, 07:25 AM
sle39lvr sle39lvr is offline
Mein Auto: 08 E90
Smile Michelin Pilot Super Sports: Thread Pattern Question
I recently got a set of these Michelin Pilot Super Sports. Their website states these as 'Directional' tires. However, the only sign on the tire in regard to this is 'Outside' indicating which side should be facing outside.
If you look at the picture above, you can see the outside shoulder has a different thread pattern; however, the cuts are angular. So if I switch rear wheels (as an example), tires still be facing correctly to outside, but the thread will be rotating opposite. This doesn't seem right to me. Any input?
Old 12-13-2012, 08:09 AM
rdorman rdorman is offline
Mein Auto: 2000 imola red 740i Sport
They are Asymmetrical not Directional. Asymmetrical are always marked with an 'outside', Directional with a direction arrow. Symmetrical may or may not have and outside. Asymmetrical and Symmetrical can be cross rotated where Directional can/should not.
Old 12-13-2012, 11:41 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
I'm not sure where you found the information that these are directional tires on the Michelin website. I looked and their website has very little information about the tire. It doesn't mention whether they are directional or asymmetrical although they are clearly asymmetrical. I have these tires on my Z4 M and they do have "Outside" molded on the tire, an indication of asymmetrical tires.
This information is from the Tire Rack website and clearly states that they are asymmetrical and makes no mention of their being directional:
The Pilot Super Sport features an asymmetric design molded of Michelinís Bi-Compound tread rubber featuring a Le Mans-inspired dry compound outboard side-by-side with their latest generation of wet compound inboard. The low-void outboard shoulder features a track-type compound to withstand the stresses of high performance cornering while the notched center ribs and inboard shoulder feature a compound designed for superior performance at very high speeds and in wet conditions.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 12-13-2012, 08:04 PM
pointandgo's Avatar
pointandgo pointandgo is offline
Mein Auto: '13 F10 535i (loaner)
If you take note of most new tire offerings in the past 10 years or so, most are "asymmetrical" rather than "unidirectional." So-called "directional" tires have lost favor with tire manufacturers in recent years due to their propensity to develop horrible "pattern noise." They had no rotation options whatsoever (although, in fact they COULD be run in the "opposite" direction without harm)...the world would NOT end.
The current "vogue" is certainly "asymmetrical" tires and everyone is piling on to this trend. As noted, the sidewall indicates: "this side out." They do offer another rotation option (unless you have a staggered fitment). If you're lucky, you have the same size all around.
The "benefit" of asymmetrical" tires is the handling aspect as the outside shoulder will have a lower "void ratio" thus accommodating higher grip in dry cornering. This harks back to the famous Michelin ASX tire of many decades ago, perhaps the first asymmetrical tire and "OEM" on many famous European cars.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
'71 AMC Javelin (4-Spd Stick on the floor)
'67 Pontiac Firebird 'cabrio' (1st car - "the leaker")
Member: BMW CCA
Old 12-13-2012, 09:56 PM
Mein Auto: 08 E90
Thanks for the replies.
I see what they are now. I did email Michelin, let's see what they say.
