Old 12-01-2012, 12:00 AM
hh3uunp hh3uunp is offline
HE's back
Mein Auto: 540i 6 01
SOMEONE HELP ME really annoying problem
So I keep cleaning the area around the gas tank cap, but it gets dirty really quickly again. My OCD is acting up again and I can't stand it,
will post pics tomorrow
I got a m5!!!!!!
Old 12-01-2012, 12:34 AM
Peter van Nispe Peter van Nispe is offline
Mein Auto: E39 523
Do you mean dirty from gas? I never have this problem.
Is the cap closing well enough? Is the rubber clean?
Maybe you should clean it up and buy a new cap?
If you mean that there is dirt in the area behind the door: that hapens all the time,
the dirt and water can't go out.
I have been thinking of drilling a hole in the bottom.
Maybe someone else has a good solution?
Old 12-01-2012, 01:26 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
Mein Auto: 1996 528i 1999 MB c240
I have the same problem whenever i wash the car ,water will collect under the cap, 1/2 a cup, and would not drain until you suck it with a tissue.
Old 12-01-2012, 09:09 AM
Nline6's Avatar
Nline6 Nline6 is offline
Always best in the NW
Mein Auto: E39 528it & E36 M3 sedan
Open the door and clean it? There is a drain hole below the filler cap.
Touring the nation, one state at a time
Old 12-01-2012, 10:12 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Not on the saloon.
BTW, it would be insane to intentionally drill a hole in the body, unless you know how to repair the factory coating. You'll be inviting rust.
Old 12-01-2012, 12:49 PM
HE's back
It's dirt build up near the gas cap. I keep cleaning it but it comes back
I got a m5!!!!!!
Old 12-01-2012, 11:50 PM
Nline6's Avatar
Originally Posted by edjack View Post
Not on the saloon.
I stand corrected, I swear i had a drain hole, i guess one of my other bmws had a small drain hole in the filler cap area but not the e39. I got curious and went and checked and I don't have a drain hole either. In fact there was a bit of water in there as well. My mistake.
If one did want to drill into the car for whatever reason, I'm sure a dab of clear coat would seal the exposed metal. Might want to put down some masking tape first to. (Although I would never want to recommend drilling a hole in your car)
