Old 07-08-2014, 10:53 PM
E-clipse E-clipse is offline
Mein Auto: 530i
01 530i will not start
I realize the topic of this post will make it appear to be like a dozen others, but it's not. My problem is today after braking hard, my car died and would not resart. When I attempted to start the car, it turned over for a few seconds then died. With the key in the 3rd position there are several lights that come stay on, but since the car will not start I don't know if this is just part of the startup diagnostic or what. Is there some kind of fuel cutoff switch or is this an extreme version on limp mode? I have searched but cannot find an answer that relates to my situation. I welcome any input that might help me solve this problem.Attachment 450614
Old 07-09-2014, 03:45 AM
nedmon nedmon is offline
Mein Auto: 1998 528i, 1987 Carrera,
Looks like the engine oil level is low. You should check it. Also were any of those warning lights on before or did they all light up when you got the starting problem
Ned,
87 Carrera
07 CRV
13 328i
Old 07-09-2014, 04:23 AM
timarnold timarnold is online now
TA
Mein Auto: 2003 bmw 525i, 2005 X3
When you say it turned over for a few seconds do you mean it ran for a few seconds, then died? Assuming that is the case, it sounds like your sudden stop initiated a major vacuum leak maybe by shifting the intake boots or maybe somehow damaging the brake master cylinder diaphragm. You could eliminate the master cylinder by pulling the vacuum line off of the master cylinder, plugging it and seeing if your car starts.
There is no engine disabling after a sudden stop feature short of the airbags deploying.
Old 07-09-2014, 04:45 AM
Mein Auto: 530i
No lights were on and the oil service light just came on yesterday when it changed from green to orange. I have had no problems with any fluid leaks, power loss, warning lights until the braking incident. I will be buying a scanner this morning after work, and also checking/ changing oil. Thanks for your reply
Old 07-09-2014, 07:09 AM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
have you checked around the battery? is it tightly held down and cant move easily? I would make sure nothing hit the battery and caused a relay/fuse to pop.
CCV Delete- So happy about it too
Street Edge Coil Overs
M5 Rear Sway Bar
Hankook Ventus V2 225/55/16
Akebono Euro Front Pads- Awesome
Brembo OE Replacement Rotors- Makes my heart flutter
Stereo Fully Upgraded- Focal, CDT, Soundstream, Kicker
Old 07-09-2014, 08:30 AM
Typing /won't start f3 in the bestlinks nets this, which may help:
- Summary of engine cranks but won't start threads due to unspecified gas air spark compression timing problems (1)
See also the very recent thread:
> E39 (1997 - 2003) > 2003 530i e39 will not start
Originally Posted by VOY530i View Post
My car cranks but will not start
It was sitting for few weeks and I wanted to move it in to garage for a winter. Tried to start and came very close to running but it didn't.
Changed crank shaft position sensor already- not starting.
Looks like it's getting gas -little valve on top of engine is squirting when pressed,plus spark plugs are wet when removed (Dried and checked twice).
Removed rear seat and can hear fuel pump humming when turning the key.
I think it's not getting the spark
Can anyone help what to do at this point ???
Old 07-09-2014, 08:36 AM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
The first thing I'd do is inspect all your major electrical connections and make sure they are clean and tight. By major I mean the connectors at the battery, starter, alternator, as well as the groups for the engine, etc.
The modules in our cars do strange things when they don't get the proper voltage. What is the battery voltage? If it's below 12 volts, you've got a battery or alternator problem. How old is the battery? You may have to have your battery and/or your alternator tested.
Old 07-09-2014, 05:00 PM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
My BMW ran just fine, I parked it at Taco Bell late one Friday night and grabbed a bite to eat, came back out, and tried starting the car, it ran for a few seconds then shut off. I tried re-starting the engine and it just cranked over and would not start. It had no codes when I checked it with my Peake Research code reader, and it turned out to be a bad fuel pump. I replaced it with a lower cost Airtex fuel pump sold by Rock Auto.com and it's been running fine. A bad camshaft or crankshaft positioning sensor could also cause it not to start, but you need to verify that you have the correct fuel pressure, and verify that you have ignition spark at the spark plugs.
This diagnostic guide may be helpful, the no spark could be a ECM relay and or fuse can also be an issue.
BMW No-Start Diagnostic Guide DIY
http://blog.bavauto.com/3562/no-start-1989-325i-e30/
BMW 5 series E39 common no start issue
Old 07-10-2014, 08:19 PM
Mein Auto: 530i
Checked all fuses and they were fine, changed relay since I had it out, but still no start. Having my Indy check it out now
Old 07-11-2014, 10:49 AM
Mein Auto: 530i
Checked all fuses and they were fine, changed relay since I had it out, but still no start. Having my Indy check it out now. Fuel pump is bad
