Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 12-01-2012, 11:30 AM
kevmoz kevmoz is offline
Mein Auto: 645Ci Convertable
Non dimming rear view mirror
Hi all,
My rear view mirror has stopped dimming and is getting right on my pip. Any ideas?
Cheers Kev
Old 12-01-2012, 12:38 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Hopefully it's just a power connection issue, a new mirror goes for about $500.
Does your clown nose LED blink red when the alarm is set? Do you have the garage door openers on the mirror which you could test for power?
You can split the cover on the mirror and check for loose connections. Instructions from the TIS.
Here is a pic of how the trim comes apart:
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-01-2012, 12:42 PM
colink colink is offline
Mein Auto: 2004 645Ci Convertible
In the US I would recommend www.radar-mirror.com They replaced the glass in mine for less than 1/5 of the cost of replacing the whole thing and now it looks and works perfectly.
It was not auto dimming as it should and the fluid between the glass layers was discolored.
Sorry, in the U.K. I do not know.
Old 12-01-2012, 02:18 PM
rebel.ranter rebel.ranter is offline
Mein Auto: 630i, 525i, 320iC
If you end up having to replace the mirror look in to replacing it with the built in compass. I have it in my e39 5 Series & it's a nice addition. You can also get it with built in programmable infrared remote controls for automatic gates & garage doors. These are OEM BMW mirrors, not aftermarket crap.
Old 12-01-2012, 05:59 PM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2012 528i + 2007 650 Vert
I think I have the same issue. My power is fine bit I don't think it's dimming. I'll look into the glass replacement too.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....12' F10/White
Old 12-01-2012, 11:38 PM
Thanks for the replies. I'll have a check of the power cables, but the alarm dome does work so I assume it's the glass.
Old 12-18-2012, 09:23 AM
Cheers again chaps. I found a spare at a breakers and £36 later I have it fitted and all is OK.
Old 12-19-2012, 01:28 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
+1 there are plenty of these car at the breakers now!!! Sad but true!!! The wing mirrors also go the same way....
Does my bum look good in this !
