E30 (1982 - 1993)
Replacement rims for e30
I have an 85 e30 and the stock rims are 14's. look like little bike rims. What size can I upgrade to without replacing shocks and springs?
16s. anything bigger looks wrong. but you have to get the correct spacing and tire.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
Thats what I was thinking about. What size tire do u recommend?
225/45 if i remember correctly. i have been wrong before
Don't put 16" wheels on stock suspension. It will increase your wheel gap and just look silly IMO
16x8 Et 5 and 3 here
24's over here
![]() as said above, change the suspension before you buy wheels.
if you want to lead the orchestra, you must turn your back on the crowd ![]() build: http://www.bimmerfest.com/forums/sho...d.php?t=382667 |
I just put a new suspension a year ago so maybe i will just out 15's. these 14's just look so tiny and small. Have plenty of room for a bit larger
what kind of "new" suspension ?
Nothing fancy just the stock brand from autohauaz.com
Sent from my MB860 using Bimmer App
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
In reality, the wheel gap does not increase. Your perception in relation to tire sidewall height and fender gap makes it seem larger. I'm running 17s with offsets 20 and15 without any issues. I also dropped the car 40mm to eliminate wheel gap.
Big Boyz with Bad Toyz. Last edited by BigBoy740il; 12-01-2012 at 07:24 AM. |
I think I just said that.
Dumb question: what do u mean by 20 and 15 offsets? What is the exact measurements of the 17's u have.
It is the space between the hub and centerline of the wheel. an offset of +45 means that the hub mounting face is 45mm towards the outside of the wheel from the centerline of the wheel itself, and 0 offset means the hub mount face is exactly in the middle of the wheel
I'm running 17x7.5 rims. The 15mm rear wheel offset allowed me to bring the wheels closer the fender well. This gives the rear a fuller, tucked look.
Big Boyz with Bad Toyz. |
