Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 12-01-2012, 01:03 PM
1slick66 1slick66 is offline
Mein Auto: 525I
Cool 1994 525i
Hi: Iam up in the air what to do with my BMW,always seem to have air in coolant,have bleed before,occurs again, it now looks like i might have water in my engine oil,possibly bad head gasket,also my fan motor i s really noisy,only works on high,was not blowing heat before, bleed again and filled with coolant now blows some heat, don't know if its worth fixing i can do it myself if i get some guidance, if i know the extent of everything, if not may sell for someone to project!
Last edited by 1slick66; 12-01-2012 at 01:04 PM. Reason: forgot to put it is a 1994 525i
Old 12-02-2012, 05:12 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
if it has a combustion leak, put a used engine, engine not worth fixing.
Old 12-03-2012, 08:35 AM
Mein Auto: 525I
Thanks, it may seem a used engine not worth it either, may just sell!!
