E60 (2004 - 2010)
Old 12-01-2012, 08:24 PM
O8528xi O8528xi is offline
Mein Auto: 528xi
Tires
I just purchased a used 08 528xi. Everything so far is fine, but I've noticed that I although there is a lot of tread on the tires, there is throbbing sound at low speeds. I'm assuming that the tires may need to me balanced and rotated. My question is this: is this something that I must go to the dealer for? Or can I go to a Goodyear for this? I am obviously a rookie, so please pardon my ignorance.
Old 12-01-2012, 11:23 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
You can go to any tire place to get your tires balanced.
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 12-02-2012, 05:12 PM
Munich77 Munich77 is offline
Mein Auto: 2008 535 xi
+ 1 Just make sure they road force balance them!
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 12-02-2012, 05:17 PM
Mein Auto: 528xi
So I got the balanced and rotated , and the guy said the problem is that I need an alignment as he noticed uneven tread wear. This is something that must be done by the dealer. My question is this: since my warrantee has not run out, is this a covered expense? And if not, how much damage will I incur? (Funds are currently limited!)
Old 12-02-2012, 05:21 PM
Gurud Gurud is offline
Mein Auto: 2013 535ix, 2007 530xiT
Go to firestone. $80 at most.
Old 12-02-2012, 05:23 PM
Mein Auto: 528xi
Cool. So Firestone can be trusted?
Old 12-02-2012, 05:45 PM
Mein Auto: 528xi
Also, I've noticed a tpm alert now. How can this be reset?
Old 12-02-2012, 06:26 PM
Do you perhaps have a leaking tire or something? As for resetting it is in the systems menu.
BMW CCA Member
Old 12-02-2012, 06:28 PM
Mein Auto: 528xi
No when I got the tires balanced and rotated, it came on.
Old 12-03-2012, 04:16 AM
tiger16 tiger16 is offline
Mein Auto: vw passat for now
Do you know how to reset it?
Old 12-03-2012, 04:18 AM
Mein Auto: 528xi
I figured it out this am. Thank you though.
Old 12-03-2012, 05:04 AM
Mac Hadley Mac Hadley is online now
Nac
Mein Auto: 535XI, 328I
I had a very negative experience with them, but in fairness, it was in the Philadelphia area and some decades below.
I would use a shop specializing in alignment and balancing.
Old 12-24-2012, 03:11 PM
craigmack1's Avatar
craigmack1 craigmack1 is offline
Mein Auto: 99' 528i
+1 - Firestone bad experience!
'04 X3(hers)
'99 528i(his-mine)
'95 325i
'84 318i
Old 12-26-2012, 01:02 PM
pedro530 pedro530 is offline
Mein Auto: 530xi
throbbing sound
My friend start with the tires and if ok hyave someone checkout your suspension .
Old 12-26-2012, 01:21 PM
Nac
Check on Tire Rack, www.tirerack.com, and read tests/reviews of your tires and see if the "throbbing" sound is a characteristic of these tires. If so, you may have found your problem. Tires vary greatly in the amount of noise that they produce.
Old 02-04-2013, 10:21 AM
Mein Auto: 530xi
I would first see dealer and get an idea of what your problem could be. Them if it is within ur budget have it fix there or get a second opinion.
Old 02-04-2013, 02:30 PM
jim165 jim165 is offline
Mein Auto: 2008 BMW 550i Sport
This thread is slightly out of date, but if you get throbbing sound from the rear, definitely check the inside of your tires for severe wear. The negative camber on these cars will wear out the inside of the tire and produce odd sounds when you're riding on the belts. I also experienced a loud roar/thrum and a squirmy rear end feel. Checked the tire from the side and tread was perfect. Took it to Discount Tire and they pulled me to the rear of the car and showed me the inside of the tire....I was riding on belts. Immediately dialed out some camber to save the new tires.
2008 550i Sport
Space Gray, Black Dakota, Bamboo Anthracite
SAT, Sat, Shades, Cold Wthr, Comf Access, Nav,L7, PDC, LUX V3 AEs, BMW Perf. Grilles, HID fogs, ACS Roof Spoiler, M5 Lip Spoiler, RPI GT Exhaust
Others:
2006 Corvette Conv, Z51,6sp (wife)
2007 Honda CBR1000RR
2005 Triumph Daytona 650 (wife)
Old 02-04-2013, 02:36 PM
Phoenix1 Phoenix1 is offline
Sleeper Wagon
Mein Auto: 2008 E61
Alignments are not covered under warranty.
I use a good independent Goodyear tire installer (on the Tire Rack recommended installer list) who does my (Road Force) alignments for $90. I also give him enough business, he will "check" my alignment for free and not charge me for the work (happened after I slammed a NJ pothole). Dealer normal price in NJ for alignment is $199, they were running a special for $129, only charged me $99 during some recent work I had done. Go to TireRack.com and click on "installation" on the home page, enter your zip code and they will give local shops they deal with - a good place to start. If your tires are worn badly, balancing and alignment won't hurt, but may not help ride/noise much. If you have the original equipment Goodyear tires (regular or especially run flats) you probably won't be happy with the ride or noise until you change them. Great cars shipped with crappy tires.
2008 E61/Monaco Blue/Natural Brown/Premium/Sport/Logic 7/Sirius/Escort 9500ci, Conti DWS. Build Date 1/08. HPFP replaced 6/10 and 4/11 Fuel Injectors replaced 3/11. Battery replaced 5/11 (warranty), sunroof seal replaced 10/11 free under SIB 540409. Pads and rotors replaced 11/11 under maintenance. Carbon buidlup on valves cleaned under maintenance 11/11. 59K miles. Original owner. BMWCCA Member. Route 66 Easy Street Warranty.
Old 02-04-2013, 06:35 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
My first question is, Are these Run Flat Tires? RFTs. If so just replace them with regular performance tires.
When I bought my 535 sedan it had Dunlop RFTs and they were god awful and made a droning sound. Basically you are driving on steel drums with a thin coat of rubber. I always advise people to just ditch them and get regular quality tires. Continental, Michelin, Yokohama, Kumho, many choices. Tire Rack does a good job on their selections and they have great phone support.
Styling: M5 body kit, M5 trunk spoiler, LED Angel Eyes, HID fogs, LED side markers, Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Zapco Z8 DSP, Zapco Z-150.6 amp, iDock on dash
Performance: JB4/G5 ISO flashed on Cobb, Meth Injection, AR Downpipes, ER FMIC and Charge Pipe, DCI, Walbro LPFP, RB turbos. H&R Sport springs/Koni FSD shocks.
