E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
325i with Bee*R Limiter
Hey chaps,
I'm putting a BEE*R rev limiter in my 325i e30 with motronic M1.1 ecu and built m20b25. Just wondering if anyone has done it before/may know which wires to tap. The manual for the limiter says one wire goes to the sensor-in signal and one to the sensor-out signal. Upon looking at other installations the 'in signal' is really just a tachometer pulse and the 'out signal' is an ignition source/crank angle sensor wire. Apparently the motronic ecu has two Crank Ref Sensor wires. I presume i wire the signal out to the positive one of these? Any help would be appreciated. Thanks
The ECU has a rev limiter in it already (unless yours is broken). How far down do you want to set it? Is this so your partner does not more speeding tickets?
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
doin mah two step
not sure how to setup a Bee-R but I have mine on a momentary switch with megasquirt. 6 psi off the line
video is old and on Pirelli p-zero's, I'm now on much stickier rubber.
![]() 400whp turbo M20 Last edited by kamotors; 12-03-2012 at 10:35 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
