Old 12-02-2012, 08:05 AM
secany secany is offline
Mein Auto: 650i F13
[Fxx] code import POI via USB? (Navigation, for import speedcam POI)
Hi,
Anyone tried to code the import POI via USB function? I want to import speedcam POI data to the navigation.
There is an option on HU_CIC , 3000 , NAVI_MYPOI_IMPORT , set it to active then it will have "import (USB)" function on option like this
But when I try to import POI, CIC always display error "insufficient memory to import all POI", no matter I try with GPX / OV2 file. I even tried with an empty txt file,it has the same "insufficient memory to import all POI".
I believe it should have another option to ENALBE or allocation memory for POI.
I don't think that file format is incorrect, as see here: it should have this error if file format is not correct.
(Credits to asaseaban from this thread: http://www.bimmerfest.com/forums/sho...d.php?t=416278)
anyone HELP please
Old 12-02-2012, 10:10 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Thanks to JEG23, have Google Trip Import, and POI Import is being studied, although the POI format itself and file structure remains unknown:
http://www.bimmerfest.com/forums/sho...225&highlight=
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 12-02-2012, 04:05 PM
Mein Auto: 650i F13
Hi Shawn, thanks for answering.
It supposes to be same on Exx using DVD disc then should be OV2 / GPX / ASC.
I attached a file contains all of those format. Could anyone try and let us know the result?
Rename the .zip.pdf into .zip and extract it please.
thank you.
Old 12-02-2012, 04:52 PM
JEG23 JEG23 is offline
Mein Auto: 550i
thank you.
Thanks Secany,
I will include these in my testing.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 12-02-2012, 04:53 PM
thank you.
Thanks.
Good luck JEG23.
- BMWCCA #446923
- flick
Old 12-02-2012, 08:19 PM
Mein Auto: 650i F13
http://www.pimp-my-nav.com
This app can add custom POI to BMW Professional Navigation (DVD Version), using OV2 / GPX , so I don't think there is any reason new CIC does not accept OV2 / GPX .
The problem is mine always show "insufficient memory to import all POI" , eventhrough file is EMPTY
I had an 650i F12 2011 before, and it come with "Import (USB)" function, without any extra coding. But on current 650i F13 2012 doesn't have. After coded, seem like "Import (USB)" not working properly.
Old 02-15-2013, 08:33 AM
Telefax Telefax is offline
Mein Auto: 535
may be this could help?
3006 TELEMATIK MY_INFO_SUPPORTED_POIS Increase CIC stored addresses/messages from 25 to 50
Old 02-15-2013, 09:44 AM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
I think that's for sending address to the car via the remote app or Google maps.
I have also enabled USB POI import on my F30, but I get the same error; no room to import POI.
