E34 (1989 - 1995)
Old 12-17-2012, 08:44 PM
Banned
Mein Auto: car
Originally Posted by jeaux View Post
I am very much revealing my ignorance here, but I don't now remember which fan it was, just that I think there are two (one is a back-up perhaps?) and they cool the engine down. So I am guessing engine fan. And I read that the fan issue is a common reason for the E-34 to have overheating issues. Actually I paid 27$ to ask.com when I was so frustrated with how my mechanic could 't figure out why it kept overheating and had spent 100's and 100's of dollars trying many non essential fixes. And the expense of those hoses! Best 27$ I have even spent!
You should get a refund from that mechanic unless he can give you a very good reason why not. The fan clutch or engine fan (the fan that you see spinning when you open up your bonnet, between the engine and the radiator) is a VERY obvious thing for mechanics to check.
It is easily checked and it is actually unlikely that they would have missed it. Perhaps there were other issues ?
Old 12-17-2012, 08:58 PM
jeaux jeaux is offline
Mein Auto: 1990 5301
Well the tricky thing is that it WAS spinning, but not fast enough...thus the overheating. All because of the deteriorating seal.
Old 12-17-2012, 09:01 PM
Banned
Mein Auto: car
Its a viscous clutch, not a seal, and no mechanic worth his salt would be unable to test that within 30 seconds.
Please, however long ago it was, go back there and get a refund. You were ripped off. We don't tolerate that. Use the money to fix your transmission.
Old 12-17-2012, 10:38 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I think she is referring to the fan clutch they lose their seal and the hydraulic oil seeps out ,thus rendering the fan useless .It can be tested with engine hot. I have seen two fan clutches fail. As for the original poster . I would focus on the cooling system symptoms and confim coolant loss first.If so look for used replacement engine.
Old 12-18-2012, 08:06 AM
Banned
Mein Auto: car
There's a damn good chance that your aux fan circuit is busted. Probably your aux fan's coolant temp sensor. Your aux fan is the backup for your clutch fan.
I'm running my car on my aux fan alone and it works fine. Have removed the clutch fan, so even if your clutch fan was busted, the aux fan should have been able to compensate without difficulty. I think you ought to take a look at that as well. Please see bentley for more information.
rgds,
R
p.s. Point taken LD.
