Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 12-06-2012, 05:55 AM
Chongo1205 Chongo1205 is offline
Mein Auto: 2005 BMW 545i
Headlights two different colors.
I noticed that the headlights on my 05 545i were two different colors. One is sort of a clear blue and the other is a shade of pink. Is this just normal "wear and tear"? Do they need to be replaced?
Old 12-06-2012, 05:56 AM
roboe60 roboe60 is offline
Mein Auto: 2005 530i
The "pink" one is on it's way out. Best to replace both at same time.
Old 12-06-2012, 05:59 AM
@roboe60: thanks! Any suggestions which headlights should I get? Is there some sort of "upgrade" headlight?
Old 12-06-2012, 06:26 AM
pcy pcy is offline
Figure out if your car has D1S or D2S and order a set of appropriate set of lights.
Old 12-06-2012, 06:29 AM
@pcy: how do I find that out?
Old 12-06-2012, 10:35 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
It says D2S on the headlights themselves. The igniter is attached to the bulb on the
D1S bulb assemblies and can be ordered separately on the D2S bulbs.
I'm not sure that you can go with the D1S assembly on pre LCI with no errors.
I've never seen it.
http://realoem.com/bmw/showparts.do?...97&hg=63&fg=05
I would go with Osram D2S 4300K xenon lights for both sides.
http://motors.shop.ebay.com/eBay-Mot...0.l1313&_rdc=1
The higher the Kelvin temp doesn't equate to a brighter bulb as many think.
Philips bulbs are good, but start out blue and immediately turn white as it
warms up. 6000K is probably the highest you should go because it really starts
to get dim and deep blue after that.
And yes, its a bright idea to change both at the same time.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 12-06-2012, 10:39 AM
Thank you all! I just went to my local luxury car repair shop and they charged me $90 each side ($180) installed.
