Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 12-03-2012, 06:51 AM
CJ645Bern's Avatar
CJ645Bern CJ645Bern is offline
youtube.com/lidlgangsta
Mein Auto: 05' 645ci & 01' z3
Replace bad headlight bulb or both?
Hey all. My passenger headlight is out(zenon bulbs). I was told by bmw dealer that they should last a long time and that only the bad bulb should be replaced. However another bmw dealer told me I should replace both cuz the other one might go bad. What do you think? Price quote on replace 1 or both is $500-900. I know its a big price difference but is that price about right? They charge a lot for labor its stupid. Thanks!
Sent from my SAMSUNG-SGH-I747 using Bimmer App
live fast, drive faster
2005 BMW 645ci Coupe (daily driver)
2001 BMW z3 3.0i vert' (TOTALED RIP)
1991 NISSAN 300zx 2+2 (gave to brother)
Old 12-03-2012, 07:33 AM
roseng's Avatar
roseng roseng is online now
Mein Auto: 2012 528i + 2007 650 Vert
That Labor charge is insane. This is an easy DYI with instructions here. This is a thread with instructions and pictures that shows you how to do it. There is an access panel in both front wheel wells that open to give you access to the housing where the lamps are. At most a 30 minute job.
I would replace both just as a confidence issue, so you know it's done. Besides with what you save doing it yourself, you can well afford the bulbs.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....12' F10/White
Old 12-03-2012, 07:36 AM
daytona745 daytona745 is offline
Mein Auto: 645CI, CorvetteZ06
I dn't know what the bulb costs but the labor charge is robbery. The following is from the owner's manual.
High beams, parking lamps
High beams
Bulb 55 watts, H 7
1. Remove the cover cap 1 by pressing
the tab and removing the cover cap
upward
2. Press the bulb holder from above to
release it
3. Remove the bulb holder
4. Remove and replace the bulb.
Old 12-03-2012, 07:40 AM
CJ645Bern's Avatar
High beams
Bulb 55 watts, H 7
upward
release it
thanks!
CJ645Bern's Avatar
thanks!
Old 12-03-2012, 09:39 AM
rdorman rdorman is offline
Mein Auto: 2000 imola red 740i Sport
Phillips D1S can be found for $100 a pair. So get some and DIY. I change both at the same time because of color shift.
Old 12-03-2012, 09:54 AM
CJ645Bern's Avatar
I have an 05. Doesnt the bumper need to be removed?
Old 12-03-2012, 10:10 AM
I am seeing conflicting information on that. TIS says to remove the trim cover yet I see plenty of info that says you can do it through the access panel. Take a peak and see if you have the access panel as pictured in the link above.
Old 12-03-2012, 10:43 AM
CJ645Bern's Avatar
I don't tho so I'm assuming I have to remove the bumper
Old 12-03-2012, 11:08 AM
That stinks. Doesn't look like a hard job though:
http://tis.spaghetticoder.org/s/view.pl?1/09/22/52
http://tis.spaghetticoder.org/s/view.pl?1/09/23/31
All the more reason to replace both though. Could always use and Indy or even a body shop if you have a connection.
Old 12-03-2012, 11:58 AM
ECSTuning's Avatar
Mein Auto: e30
Per my notes you're going to have D2S bulbs in your Low beams and H7s in your High beams, I have a variety of bulb options for your car available HERE. Typically for sake of color matching we suggest replacing them in pairs, but if you'd like you can just replace one.
800.924.5172
OEM BMW Part Number Search
Old 12-03-2012, 02:28 PM
euhysh euhysh is offline
Mein Auto: 2008 650i Coupe 6MT BSM
My buddy's 05 SLK bulb went out on one side. He bought a replacement and the shade was slightly off. Not really noticeable...but I'm guessing these HID bulbs change color ever so slightly over the years.
Old 12-03-2012, 07:36 PM
CJ645Bern's Avatar
Can anyone give me an ebay link or something for the bulbs? Maybe the philips ones your talkin about. Thanks
Old 12-03-2012, 09:45 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Here are the Philips for $60 a PAIR at a popular BMW parts site.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-04-2012, 06:23 AM
They do shift in color. One of the reasons I just replace both.
Old 12-04-2012, 11:56 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
It's possible the headlight unit it bad, in which case the charges would make sense and you'd only want to replace the bad one. If it's just the bulb, buy a pair and replace them yourself.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 12-05-2012, 11:46 AM
E92-Lighting's Avatar
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
we are fully stocked with your MTEC D2S 6 bulbs, its error free or you can keep the product for free.
Old 12-05-2012, 02:09 PM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2007 BMW 650 vert
If you don't have the access hatch, then here are links for the front bumper removal. I removed my front bumper to replace a foglight and I'm not much for DIY - fairly easy and took < 30 minutes.
link to DIY front bumper removal:
http://www.bimmerfest.com/forums/sho...=bumper+remove
Link to TIS instructions for front bumper removal:
Regards, Greg
'07 650i vert, creme beige/jet black, sports & cold weather pkgs, comfort access, premium sound, sat radio, Miro M6 wheels, tint, windscreen, triple resonator delete, 5W bulbs, corner bulb delete and m-tec fogs
'11 Acura MDX Advance with Entertainment pkg for the family - no mod's
Old 12-05-2012, 04:32 PM
roseng's Avatar
Look in the wheel well. Turn your wheel all the way to the right and use a flashlight. On your left facing the front of the car you should see a small door with one screw holding it on. Remove the screw and that should get you access to the back of the bulb housing area.
You need to remove the bumper to remove the headlight assembly, not to replace the bulb.
Old 12-05-2012, 04:52 PM
CJ645Bern's Avatar
I just noticed there is a panel in the wheelwell. Can I access the angel eye bulb as well?
Old 12-05-2012, 04:58 PM
petriej's Avatar
Maybe, but you should be able to reach it from above with just the hood open. Maybe find someone with small hands if it is tough.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-05-2012, 08:45 PM
CJ645Bern's Avatar
sweet just bought em! thanks! but do u know if theyre error free?
CJ645Bern's Avatar
thanks for all the replies guys! i really appreciate it!
Old 12-05-2012, 10:31 PM
Yorgi's Avatar
Philips are one of the best quality bulbs available, so yes, error free for sure. OSRAM and Philips are two of the larger OEM suppliers.
$60 is just a tad better than $900 that the dealer wants.
'04 M3 - track
Old 12-06-2012, 11:03 AM
umnitza's Avatar
umnitza umnitza is offline
• www.umnitza.com •
Mein Auto: ///M
We offer D2S bulbs from $39.99 for a pair and up, that's all you need along with a DIY
Join Our Facebook! - Check Out Photos, Talk to Customers, Ask Us Questions!
Call US! 877 486 6489
Available: 9am-5pm M-F
