Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 12-03-2012, 06:59 AM
kyfdx's Avatar
kyfdx kyfdx is offline
Who, me?
Mein Auto: 2006 330Ci ZHP
E30 back-up lights
No other electrical problems, but the back-up lights have stopped coming on.. ('87 325iS)
Can you tell me the most likely place to start looking? Is it likely to be a fuse, or would that cause other issues as well?
2006 330Ci ZHP Imola Red
2011 X3 Bluewater
1987 325iS Bronzit (retired)
2011 Z4 Space Gray (retired)
2008 X3 Sapphire Black (retired)
2005 330Cic Silver-Gray (retired)
2003 325i Sport Steel Blue (retired)
1967 2000CS Delphin Gray (retired)
Old 12-03-2012, 08:51 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Start simple: fuse. If that is good, test each bulb, and test for voltage at the bulb/socket. One going out is possible, but both at the same time points to other areas common to both. Now it gets a bit harder: the reverse switch on the transmission. Is it a 5-speed or automatic?
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 12-03-2012, 07:09 PM
kyfdx's Avatar
Who, me?
It's a 5-speed... Bulbs don't seem likely, with both going out at the same time....
2011 X3 Bluewater
Old 12-03-2012, 09:26 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
there is a switch on the side of the gearbox up near the top with two wires going into it, will be hard to reach/see, you will need the car on blocks to get to it. Of course, first check the wires are present/attached, and then you can test for continuity
Old 12-03-2012, 09:27 PM
D'oh, You kids!
You'll need to check the reverse switch. You have to do it from under the car.
Edit: Ya beat me to it, Andy!
Name:	E30 backup light switch.jpg
Quotes to live by:
BMW-CCA #441426
Old 12-04-2012, 11:08 AM
kyfdx's Avatar
Who, me?
Thanks... we will check that out.
2011 X3 Bluewater
e30, lights
