Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - Current)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 12-12-2012, 01:52 PM
Ace535i's Avatar
Ace535i Ace535i is offline
Mein Auto: Xe
Originally Posted by Bungler1 View Post
I bought from BSW, system sounds great in my Z3
Sent from my GT-I9000M using Bimmer App
Would you share what BSW supplied, and how was it installed? What was the final cost?
Old 12-12-2012, 02:56 PM
Bungler1 Bungler1 is offline
Mein Auto: 1998 BMW Z3 2.8
BSW supplied the entire 6-speaker set (all but subwoofers). they were a very simple plug&play installation, no alterations to existing wiring or mounting locations. Cost was excellent at approx $250.
very clear, easily heard at speed, top up or down.
ordering was simple from their website. Shipping was prompt.
They also supply ipod-sat radio integration hardware.
Old 12-12-2012, 03:53 PM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
BSW does not have a speaker replacement set for the F12/F06 yet. It could be possible that the E92 set (shallower than the E90 Sedan) may fit.
Old 12-15-2012, 03:37 AM
Ace535i's Avatar
Mein Auto: Xe
Can I buy a portable hard drive like the Seagate 3TB, download my music, and play the music thru the USB port in the center enclosure or glove box? If so, how would I format the hard drive, and how should I keep a charge on the hard-drive while listening?
Old 12-18-2012, 05:10 PM
weissja weissja is offline
Mein Auto: 2013 550i M Sport
I just had a Reus Audio System installed in my 550 that already had the premium sound system. It sounds great. My 4th system with them. It truly is a "system" designed specifically for your particular car that adds on and works with the existing premium sound system. Really a fair price for the end result. Was actually cheaper than going to a high end shop and letting them install off the shelf components. Feel free to PM for more info.
Old 01-02-2013, 07:49 PM
Ace535i's Avatar
Mein Auto: Xe
Originally Posted by Technic View Post
Sirius =32kps-48kps
CD burned into HDD = 128kps WAV
Bluetooth streaming = 229kps-345kps/by the source compression, i.e. if the source material is highly compressed (128kps for example) then BT audio resolution will be closer to 128kps than to 229kps. To get as close to 345kps as possible then the source should be a commercial CD.
USB = up to 320kps; if the source is 320kps then it will play at 320kps
Commercial CD = 1411kps
That's what you found out by listening without the technical mumbo jumbo.
Do all devices which transmit a BT signal for music operate under the same standards across all brands as WiFi operates under an industry standard?
Old 01-03-2013, 02:29 PM
Technic's Avatar
Test... 1, 2 ,3
Yes... search for "A2DP".
As you can see, the kbps standard is quite wide.
Old 01-03-2013, 04:07 PM
Ace535i's Avatar
Mein Auto: Xe
So two devices can transmit lossless music via BT at different rates, creating lossy music?
Old 01-03-2013, 07:05 PM
Technic's Avatar
Test... 1, 2 ,3
No current smartphone transmit lossless, even via USB. And the Combox can only handle a max of 320kbps anyways.
Put it this way, between BT Audio and an MP3 encoded at 320kbps played via the USB the MP3 will sound better.
Old 01-03-2013, 10:05 PM
Ace535i's Avatar
Mein Auto: Xe
Why does the BT audio not transmit at 320kbps or higher? If so, then why is there not one standard?
Old 01-04-2013, 03:17 AM
Technic's Avatar
Test... 1, 2 ,3
Please search for A2DP... it will give you all the details that you are asking for.
