E90/E91/E92/E93 (2006 - 2013)
Make service engine soon light go away?
I currently drive a 2008 328I and my yellow service engine soon light is on due to a recently added cold air intake. Is there any way to reset it or make it go away without going to the dealer or mechanic?
Thank you in advanced. |
What did you do with your Hot film Mass air flow meter? If the new intake system doesn't have the ability to accept that sensor you probably
shouldn't use that intake system. You could do some drilling to make it work. By the way since you're running an E90 328i you're better off just getting a reuseable drop in filter. Unless you're running your "cold air" intake from a wheel well or outside the engine bay, or unless you're running an Arma supercharger, it's best to leave the factory intake box as it draws air from outside already. You knew this already though. Good Luck.
Check your mirrors as often as it takes for you to know where everyone is around you! |
I appreciate your response I am not thoroughly educated in cars which is kind of why I'm on here. I did keep the sensor in there because the cold air intake had a spot for it. Ill attach a picture below. Is there anyway to reset the service engine soon light or will it constantly think that somethings not right and come back on? Thanks again I appreciate it.
Yes. Wouldn't you like to know which codes were thrown? Likely it will return. I refer you to e90post for educational experience! . Last edited by CALWATERBOY; 12-03-2012 at 03:29 PM. |
Is that an oiled filter by any chance .
The kind that can fowl the MAF Sensor do to too much oil on the MAF Sensor.
If you get a coding setup or a BAV tool you can reset stuff and read what your problems are. With a coding setup you can also code stuff . http://www.e90post.com/forums/forumdisplay.php?f=368 http://www.e90post.com/forums/forumdisplay.php?f=16 Last edited by ctuna; 12-03-2012 at 03:58 PM. |
There is a tool to reset it, but again, you really should check to see what the code is, and fix the issue.
http://www.bimmerzone.com/Diagnostic...ST06-EI07.html or http://www.bimmerzone.com/Diagnostic...nic/BT-EK.html Good luck!
![]() | Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 | Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
