Old 12-04-2012, 08:20 AM
Sean's Avatar
Sean Sean is offline
Mein Auto: BMWs
Auto Start/Stop
Is it present on the 2013 MY X5s?
Old 12-04-2012, 09:20 AM
BimmerX5D BimmerX5D is offline
Send a message via ICQ to BimmerX5D
Mein Auto: 2012 X5 xdrive35D
It is only standard on 50i. What is your model
Old 12-04-2012, 10:55 PM
henrycyao henrycyao is online now
Mein Auto: BMW X5 35d
X3 forums has boat load of people complaining about auto start stop. I am not sure you really want it. Most reviewers complained about it as well. You should browse that area to see what people say about it. It actually can degrade your fuel efficiency if your stopping time is too short.
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 12-04-2012, 11:34 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
I have the stop:start on my M3 and rarely use it. If I know I am going to be sitting a while(long ass line at slow drive through), I will use it. Other wise I turn it off. I found it annoying when pulling up to a stop light which is going to change in 3 seconds and having the car shut off and the starting back up 2 seconds later. It is a nice feature for some situations.
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 12-05-2012, 09:41 AM
Sean's Avatar
Mein Auto: BMWs
I asked as I am curious if this can be applied to the 2013 5.0i?
SI B12 15 12
INFORMATION
The Automatic Start/Stop (MSA) system is a further BMW Efficient Dynamics measure aimed at meeting BMW’s commitment to reducing CO2 emissions and enhancing fuel economy.
BMW, always a leader in innovative technology, will be the first automobile manufacturer to bring MSA technology to all new models.
Automatic Start/Stop systems will become prevalent in the future, as manufacturers strive to meet increasingly stringent emissions and fuel economy requirements.
By automatically switching the engine off when the car is stationary, MSA can improve fuel economy and reduce emissions.
New F-vehicles now incorporate the second generation of MSA (MSA II), which has been further developed to operate in combination with an automatic transmission and the BN2020 electrical system.
A detailed description of the MSA Automatic Start/Stop function can be found in the ICP Technician library under Technical Training course ST1112.
SITUATION
Some drivers have expressed the desire to deactivate this function in certain situations. This can be done manually via the Automatic Start/Stop function button with the LED switched on, indicating that the start/stop function is deactivated.
However, by default, the Automatic Start/Stop function is reactivated each time the engine is started.
At the request of an owner, it is possible to modify this default logic to “Last user mode.”
With this logic, the current MSA’s activated or deactivated setting is stored and used on the next trip.
Note: All new BMW M models have the “Last user mode” as the default setting from production.
PROCEDURE
Explain the benefits of the MSA technology to the customer:
The environmental benefit of reduced greenhouse gases and the financial benefit of improved fuel economy
The attachment is a document that you can share with customers, which provides an overview and answers to some of the most commonly asked questions. It should be given to all customers at the time of sale, and placed inside service loaner vehicles equipped with MSA.
Should a customer still request “Last user mode,” submit a PuMA case entitled “Activate MSA memory conversion.”
The IBAC code necessary to perform this conversion will be provided in the response to the PuMA case.
Using the latest version of ISTA/P, perform the conversion “Activate MSA memory,” along with a complete vehicle coding and any required programming as determined in the measures plan.
Upon successful completion of the measures plan, the option OMSA is added to the vehicle order.
Note: When the ISTA system message displays: Battery voltage only “XX.XX” V. Please connect charger. Please note the displayed battery voltage reading in the repair order comments section.
WARRANTY INFORMATION
The conversion procedure outlined above can be submitted for reimbursement, one time on eligible vehicles, during the BMW New Vehicle/SAV Limited Warranty coverage period of 48 months or 50,000 miles, whichever occurs first.
Old 12-05-2012, 10:24 AM
smyles smyles is offline
Mein Auto: X5
I'm curious, every time I switch the engine off, the car goes in P and slightly jerks, which I assume is some pressure released in xDrive. Now, with Auto start/stop, is it the same? Would be very annoying. If not, then why the hell we have jerking?
Old 12-05-2012, 11:06 AM
alexmish alexmish is offline
Mein Auto: 2013 X5 35d loaded
I've figured this nice work around with the ASS. If I about to stop at traffic light which will switch back to green "soon", I just shift the transmission in "SD" mode (shift to the left) - it will temporarily disable the ASS, and also helps with acceleration off the line. So no need to reach out under the steering wheel (which could also lead to accidental turning off the engine!).
Hers : 2013 335xi Imperial Blue/Black with lots of stuff...
His : 2013 X5 35d Deep Sea Blue/Black with all packages
Previous : 2010 335xi Monaco Blue/Black with just about every option...
Previous : 2008 X5 4.8i Space Gray/Black with just about every option...
