Old 12-03-2012, 02:58 PM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
How much harder is removing a automatic gear box compared to manual
I took my manual gear box out of my car to do a clutch job. I saw a 540iA with a bad transmission and it comes with a used transmisson. How hard is removing an automatic gear box compared to a manual ?
If first you don't succeed you must try again, and then again
Mods
Dinan S1, Drilled slotted rotors, Akembo Pads, 19 in MPars,Zoinsville Super duty kit,
Resident Grammar and Spelling expert
Old 12-03-2012, 04:03 PM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
It's not much more difficult. It's easier in some ways. The transmission doesn't have to move back as far before it can be dropped because you don't have to work around the clutch. The torque converter has to be disconnected from the flywheel though. It's a pretty straight forward process though. You just have to remove the access plug and rotate the crankshaft around with a long-handled ratchet and socket to find each of the bolt attaching the flywheel to the torque converter.
The biggie is that the auto trans is much heavier than a manual. You're going to want a transmission jack to do the swap.
Old 12-03-2012, 07:00 PM
hh3uunp's Avatar
Ball Don't lie
Second question
When I replace the automatic with a manual I need the driveshaft but not the diff right?
I have NCS expert to code the ECU for manual
Mods
Old 12-03-2012, 07:45 PM
NADAVAN
According to realoem, the driveshaft for an auto trans car is 1521mm.
A manual trans car has a driveshaft of length 1609mm, a difference of about 3 inches.
I made some assumptions that this is a US spec car built in Jan 2001. I don't know if a different production date would have different specs, but I don't see why they would.
The auto trans car has 3 different differentials listed, one of which is the same as the only differential listed for the manual trans car. This is a 2.81 rear end ratio. The other two diffs are both 3.15 ratios. I'm not sure what the difference is between the two of them. Regardless, I'd say you're fine keeping the original differential and swapping the driveshaft.
Old 12-03-2012, 07:50 PM
hh3uunp's Avatar
Ball Don't lie
Thanks man!
Mods
Old 12-03-2012, 08:08 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
hh3, I think you are less than 20 miles from me, I have a tranny jack.
I'd also like to see your NCS.
PM me if you want to borrow my tranny jack.
2000 540/6 Slightly tweeked...everywhere
